long list of questions
  • Thread starter Thread starter Bihari, James
B
Bihari, James
<table dir="ltr">
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">A few weeks ago I got my engine back from the engine guy and have had the car out in the water a few times.<span style="mso-spacerun: yes"> </span>It’s a lot of fun but I have a few questions:<span style="mso-spacerun: yes"> It's a long list but I'll gladly accept answers to any</span>
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><span style="mso-spacerun: yes">of thequestionsanyone might choose to answer.</span>
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><span style="mso-spacerun: yes"></span>
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><span style="mso-spacerun: yes"></span>(My car is a 1964, so I guess it’s an earlier style.)<span style="mso-spacerun: yes"> </span>Jim Bihari (bihari.1@osu.edu, toll free 866-487-7211)
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><xml:namespace prefix="o" ns="urn:schemas-microsoft-com:office:office"></xml:namespace><o:p></o:p>
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">I’m going to email this to Gordon’s as well as the yahoo list in case anyone has any suggestions.
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><o:p></o:p>
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">1. The engine guy took all my tags off of all the wires.<span style="mso-spacerun: yes"> </span>There is a blue wire with a female spade connector on the same group as the two (brown and large black) that go to the generator, and that blue wire is just laying there not connected to anything.<span style="mso-spacerun: yes"> </span>Everything seems to work.<span style="mso-spacerun: yes"> </span>Can someone look at the generator in their car and trace the wires back until you see a third blue wire that branches off and tell me where that wire is supposed to go?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">2. Rear marine light pole connection.<span style="mso-spacerun: yes"> </span>We have power to the socket to the marine light pole fits into and the marine light itself works, but the light doesn’t work when put into place, so there must be some problem with the way the pole fits into the socket.<span style="mso-spacerun: yes"> </span>We once found two tiny curved brass pieces on the floor and I wonder if they somehow fit into the socket or are we missing pieces for the bottom of the pole?<span style="mso-spacerun: yes"> </span>At the bottom of the pole, there is a pointed connection at the end and then there is a second connection imbedded in the black plastic but there is no way it will touch the ground connection of the holder.<span style="mso-spacerun: yes"> </span>What is missing from what piece?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">3. Carburetor.<span style="mso-spacerun: yes"> </span>The rebuilt carburetor we bought has been trouble since we got it.<span style="mso-spacerun: yes"> </span>I’ve now used the car for about 7 days and 300 miles (one long trip in October) and gasoline always leaks out when you shut it off and it often backfires.<span style="mso-spacerun: yes"> </span>Also, it’s almost impossible to start with a few minutes of being shut off because the carburetor is flooded with gasoline.<span style="mso-spacerun: yes"> </span>This makes filling up at a gas station embarrassing because it won’t start after you fill it.<span style="mso-spacerun: yes"> </span>(It’s not vapor lock—I put in an electric fuel pump but don’t use it because there’s too much gasoline in the carburetor.)<span style="mso-spacerun: yes"> </span>The engine guy said that the needle valves are not shutting off and this is why it leaks gasoline and floods.<span style="mso-spacerun: yes"> </span>I heard others say that some gasoline leakage is common, but can you guys start your cars after they’ve been shut off for only several minutes?<span style="mso-spacerun: yes"> </span>Does Gordon’s have new carburetors yet?<span style="mso-spacerun: yes"> </span>I’d like a get a good one or have this one rebuilt properly.
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">4. Source of water leaks.<span style="mso-spacerun: yes"> </span>It sure seems like this car takes on my water than it should.<span style="mso-spacerun: yes"> </span>We had EVERYTHING off of this car body and had it up on a rotisserie where they welded shut one hole in the rocker panel and filled some pinholes under the battery tray with fiberglass.<span style="mso-spacerun: yes"> </span>The (new) boots (steering, axle, emergency brake) seem good.<span style="mso-spacerun: yes"> </span>I know it leaks a tiny bit around the doors and front hood seals even though those are all new.<span style="mso-spacerun: yes"> </span>I’d say we use the bilge pump for 15-20 seconds every five minutes in the water.<span style="mso-spacerun: yes"> </span>I tested my two bilge pumps—one fills a 4-gallon bucket in 30 seconds, the other pump (which I don’t use much) fills it in 60 seconds.<span style="mso-spacerun: yes"> </span>So I’d say, it must be taking on about 3 gallons of water or so every 5 minutes and I cannot figure out where.<span style="mso-spacerun: yes"> </span>I had the rear seat out and was trying to see if it was coming in around the axel boots but they looked fine.<span style="mso-spacerun: yes"> </span>What is typical for water leakage and where can that much water leak in?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">5. The three bolts that hold the exhaust pipe on the manifold keep coming loose and no one seems to have that triangular gasket (Gordon’s and NAPA didn’t have it, so we made a temporary one out of asbestos).<span style="mso-spacerun: yes"> </span>The loose exhaust allows the tail pipe to drop and you would think this could allow some leaking into the rear hole of the body where the exhaust comes out, but usually the exhaust outlet is above water, isn’t it?<span style="mso-spacerun: yes"> </span>Anyone find gaskets anywhere or have opinions about how to keep those bolts tight or know if much water would leak in there?<span style="mso-spacerun: yes"> </span>Thoughts about welding the exhaust pipe to the manifold to keep it in place?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">6. We had a new top from Gordon’s put on by a professional top installer.<span style="mso-spacerun: yes"> </span>The first time we tried to put the top down, I forgot to unzip the side zippers.<span style="mso-spacerun: yes"> </span>We did not force it at all, but we really gentle and noticed it wasn’t folding up, so we opened it up and unzipped the zippers.<span style="mso-spacerun: yes"> </span>The zipper pull on my friend’s side completely came off the end of the zipper track when she tried to unzip it.<span style="mso-spacerun: yes"> </span>I got it back on, but now I need some kind of staple to put across the zipper track to keep it from coming off all the time.<span style="mso-spacerun: yes"> </span>Also the bottom of each zipper track is starting to tear the top fabric.<span style="mso-spacerun: yes"> </span>Even before this happened, the top installer guy pointed out that the zippers on the new top do not go all the way down into the double thickness fabric like the original top so they are more likely tear away.<span style="mso-spacerun: yes"> </span>This was the more expensive top, and considering the cost of professional installation, I’d like to find a way to repair the torn area around the bottom end of the zipper.<span style="mso-spacerun: yes"> </span>Any suggestions for repairing a small tear in a brand new white top?<span style="mso-spacerun: yes"> </span>I was thinking of adding 1 or 2 snaps along the side at the back of the frame so that I could avoid zipping the zippers all the way shut and avoid stress on the torn area.<span style="mso-spacerun: yes"> </span>Any reason that it would be bad to add snaps (like the three snaps that are already on each side, only farther back near the zipper area)?<span style="mso-spacerun: yes"> </span>The bolt holding the base of the snaps to the metal frame would have to go through the top fabric about an inch from where the zipper is—any thoughts that that might make it tear a different place?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">7. What does Double Clutch mean?<span style="mso-spacerun: yes"> </span>I find that shifting into 1<sup>st</sup>, 2<sup>nd</sup> or Reverse, even when I have the car completely at rest seems to result in the gears grinding.<span style="mso-spacerun: yes"> </span>Maybe I need to adjust the clutch to be more disengaged when I think the pedal is to the floor?<span style="mso-spacerun: yes"> </span>What gears are supposed to be synchronous?<span style="mso-spacerun: yes"> </span>Shouldn’t I be able to shift into all gears when stopped without hearing a grinding noise sometimes?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">8. Last year I bought two of the chrome headlight rings (part 10-32-05) “Chrome replacement to the original rim.<span style="mso-spacerun: yes"> </span>“This is not 100% original, but fastens exactly as the original.”<span style="mso-spacerun: yes"> </span>I’ve had 4 or 5 people look at them and try to figure out how they fit, then scratch their heads and shrug their shoulders.<span style="mso-spacerun: yes"> </span>That spring clip pops right out and even if you solder it in place, there doesn’t seem to be any appropriate tab for it to clip behind.<span style="mso-spacerun: yes"> </span>Are the chrome rings Gordon’s are now promoting like the originals or the same as the ones sold last year and if so how do they fit?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">9. How does your Amphicar handle going around gentle turns at high speeds (over 45—like gentle curves on freeways etc.)<span style="mso-spacerun: yes"> </span>I find that it seems like I end up making more of a polygon path than a circular path (turn the wheel a tiny bit, then straight, turn the wheel a tiny bit, then straight, turn the wheel a tiny bit etc.) due to the way the steering wheel seems to stick in place.<span style="mso-spacerun: yes"> </span>Is that normal for an Amphi?<span style="mso-spacerun: yes"> </span>Also, since the guys had the front wheels off the body to put it on the rotisserie, the steering wheel does not line up to properly show straight ahead.<span style="mso-spacerun: yes"> </span>That steering wheel doesn’t have a spline on it does it—isn’t it just a shear pin that fits in one location, so I’d need to adjust all the nuts on the steering linkage to get the steering wheel to indicate straight ahead?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">10. Anyone want to make an offer on a set of 1147 .040 over pistons I bought on ebay for $50 (two identical, then 2 others each different) or a complete set of .040 over rings I bought from Advanced Performance Technology in CA for $66?<span style="mso-spacerun: yes"> </span>We ended up installing the set of .020 pistons we got from Gordon’s.
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">Thanks in advance to any answers to these questions.
<span style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: Arial; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Jim</span>
<table style="BACKGROUND-COLOR: #ffffff" bgColor="#ffffff">
<font face="Arial" size="2">James, </font>
<font face="Arial" size="2"></font>
<font face="Arial" size="2">Quick answers to important stuff. </font>
<font face="Arial" size="2">Carb, float chamber needle isn't sealing properly, just take apart and clean - shouldn't need new.</font>
<font face="Arial" size="2">A "repair" with glassfibre paste isn'ta repair - do it properly !</font>
<font face="Arial" size="2">Put masking tape over the 3 holes in the door rocker, then any leaks from door will come into car and can be seen.</font>
<font face="Arial" size="2">A sorted Amphicar will leak no more than a cup of water an hour. </font>
<font face="Arial" size="2">Gasket should be available but it is early Triumph so may be difficult but can be made. Pipe will come loose if you use steel nuts, they should be brass, again common to 1962 Triumph. Don't try and weld it ! It will wreck the parts and not fix the problem anyway as manifold is cast.</font>
<font face="Arial" size="2">Best solution for the top is to use Velcro or extra studs on the vertical part - the zippers are a waste of time. </font>
<font face="Arial" size="2">Double de-clutching - done properly you don't need to use the clutch at all, it is about syncronising gearbox internals to engine speed, but takes practice (not in Amphi) look it up in Google or Wikipedia. </font>
<font face="Arial" size="2">Amphi is sensitive to badly adjusted suspension, play in steering joints, bad tyres etc - you need to drive a good one to understand, I think the best in the US is John Friese. 70mph+ is no problemand should be relaxing (except for engine noise). Amphi brakes are not as sharp as a modern cars and the wipers never work well but at normal freeway speeds it should feel at least as good as most others cars of the 1960s. </font>
<font face="Arial" size="2">Hope that helps, </font>
<font face="Arial" size="2">David C</font>
> 1. The engine guy took all my tags off of all the wires. There is
a blue
> wire with a female spade connector .....
Oil pressure sending unit located just below the distributer.
You will need to replace the female socket. Those pieces are from
the center pin contacts. Hugh sell a nice aluminum replacement.
> 3. Carburetor.
Do you have the thick (about 1/4") phenolic spacer between the
manifold and the carb? This insulates the carb somewhat to keep the
heat from the manifold from boiling the gas. This is a common
problem related to design and not carb failure.
A common source is the 30 or so screws that hold the 2 rear
horizontal bumper halves on. Check the seal around the tow hook and
the dubo nuts on the front and rear bumper bolts. Tape over the 3
holes in the door sils before going out. This will redirect thewater
coming in over the lip so you can gage the amount.
Remove the rear seat and have the top down, engine cover up. Get a
BRIGHT flashlight and look closely around the engine compartment.
coming
Your gasket will work fine. You can use nuts and bolts with lock
washers. Do you have lock washers on there now? DO NOT WELD IT! I
you need in there again, it will be a pain to grind them off.
installer.
Tommy in Tampa has the zippers replaced with Velcro, no more torn
tops. I rarely zip my zippers. Even on road trips, I snap the snaps
and that works well. No need to add more unless you want to.
Double clutching is when you depress the momentarilly clutch an
extra time between shifts to line up the gears. It goes like;
depress clutch, move to neutral, depress clutch and release, depress
clutch to move into gear.
32-05)
I have not used Gordons rings.
speeds.... linkage to get the steering
Pull the column clamp below the dash, then loosen one of the clamps
that are in the u-joint at the base of the column. Pull the column
out and There you can rotate the wheel to be straight.
Sounds like there is something not assembled correctly in the front
end. It should turn smoothly and no sticking ever.
John Bevins
Re: Re: long list of questions
Going back to question #9, I seem to have the same problem he does, How do
you go about finding what the problem is/ Could it be a tire pressure or
shock problem? What about instalkling a brace on the steering shaft where it
goes thru the hull, will that help at all?
To: <amphicar-lovers@yahoogroups.com>
Sent: Tuesday, June 13, 2006 7:39 PM
Subject: [amphicar-lovers] Re: long list of questions
a blue
> 3. Carburetor.
coming
> 6. We had a new top from Gordon??Ts put on by a professional top
installer.
32-05)
> ??oChrome replacement to the original rim.
John Bevins
THE AMPHICAR-LOVERS LIST
Please support our sponsors while ensuring the very best restoration
services for your Amphicar. Please pay a visit to:
http://www.midwestamphicar.com
The amphicar list is a seperate service from the International Amphicar
Owners Club. Do join the club today at http://www.amphicar.com
To Unsubscribe from this List, just send a blank email to:
amphicar-lovers-unsubscribe@yahoogroups.com
Before posting requests for information, please check the List
http://www.escribe.com/automotive/amphicar/search.html
For more information about this List and other available services
http://groups.yahoo.com/group/amphicar-lovers/
Any other issues may be addressed to the List owner (Mike Israel) at:
amphicar770@yahoo.com
Yahoo! Groups Links
Assuming your front shocks are reasonably good and your front end
alignment is good, the main thing that causes Amphicars to be unstable
at high speed is the front tire pressure. With bias ply tires inflate
the fronts to 14 lbs. and the rears to 30. With radials run the
fronts at no more than 18lbs and the rears at 30.
My two Amphicars both have larger 1296 engines and both of them track
just fine at 80+ MPH. If the front tire pressure is too high the cars
tend to wander at highway speeds but they behave just fine when
properly adjusted. Just keep in mind that the wheelbase is rather
narrow and the center of gravity rather high. I drive my cars
accordingly and don't try laying them into turns too fast. Pretend
you're driving a fast Jeep CJ.
How do
pressure or
where it
> From: "a_colo_native" <rma@...>
> a blue
> > 3. Carburetor.
> coming
> installer.
> 32-05)
> John Bevins
> Archives:
> visit:
> amphicar770@...
> Yahoo! Groups Links
There are many versions of such a brace in use. Mine is hereand a search of the archievs for "steering brace" should yieldat least 2 or 3other ideas too. Shocks could contribute to it's drive-ability as well. Try John Friese's suggestions and see how it helps.
John Bevins
Concerning theshocks, has anyone found a replacement shock that works without major modifications?
John Friese <jfriese@mindspring.com> wrote: <blockquote class="replbq" style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid"> <div id="ygrp-text"> Assuming your front shocks are reasonably good and your front end
just fine at 80+
--- In amphicar-lovers@<wbr>yahoogroups.<wbr>com, " Fran" <yhprum.fa@.<wbr>..> wrote:
How do
pressure or
where it
> To:
<amphicar-lovers@<wbr>yahoogroups.<wbr>com>
> a blue
> > 3. Carburetor.
carb failure.
> coming
> installer.
> 32-05)
> John Bevins
> ~~~~~~~~~~~~<wbr>~~~~~~~~~<wbr>~~
> http://www.midwesta<wbr>mphicar.com
> Owners Club. Do join the club today at http://www.amphicar<wbr>.com
> To
> amphicar-lovers-<wbr>unsubscribe@<wbr>yahoogroups.<wbr>com
> Archives:
> http://www.escribe.<wbr>com/automotive/<wbr>amphicar/<wbr>search.html
> visit:
> http://groups.<wbr>yahoo.com/<wbr>group/amphicar-<wbr>lovers/
> amphicar770@<wbr>...
> Yahoo! Groups Links
</blockquote>
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
<table>Thank you to all for all of your good answers,
1. I guess my one top question was: has anyone had any luck with any kind of glue that would repair a couple of half inch tears in the new white vinyl top where the zipper fastens. The top installer guy thought that the new top would just continue to tear along the zipper (and it is a tear all the way through the new top--if I don't install some other kind of snaps to keep it from flapping in the wind I think it will tear more.)
2. I haven't yet put back on any of the aluminum trim over the fins, taillights, headlightsetc. etc. or any of the
side bumper aluminum. Wehaddrivenoff that fin trim with a wooden block tapped with a hammer. Except
for the left eyebrow it's pretty good shape, but a little wavy from the removal. How well will it straighten out
when it's put back on the fins etc.? Would it ruin the new paint if I had to remove it again to put on new trim? What do you think of the new stainless trim that I guess Allan Woodcock now sells (according to a
tip from Cigarman, thanks!) Does all of that trim just stay on due to a tight fit or is any kind of adhesive involved? I need to get Allan Woodcock's number I guess.
Thanks again!
Jim Bihari
bihari.1@osu.edu
toll free: 866-487-7211
Jim,
You can have your original aluminum parts restored at a place in North
Hollywood, CA called Ano-Brite. Their web site is:
http://www.anobrite.com/home.html
They can straighten the old pieces, polish out minor nicks and
reanodize them with the original brite dip anodizing process. I had
mine done there a few years ago and was amazed at how good a job they
can do, even with bent up fin strips. They came back a perfect match
to some NOS strips that I had bought for another Amphi I was also
doing at the time.
The price varies with what needs to be done, and buying Allan's might
be cheaper, but it's an option you should know about.
--- In amphicar-lovers@yahoogroups.com, "Bihari, James" <jbihari@...>
kind of
vinyl top
new top
the way
keep it
> taillights, headlights etc. etc. or any of the
> side bumper aluminum. We had driven off that fin trim with a wooden
block
I had to
stainless
> Thanks again!
> Jim Bihari
> bihari.1@...
any kind of
white vinyl top
Look in your area for vinyl repair or Call a local upholstery shop
for reccomendations for a repair guy. I have had several tops with
serious tears repaired with great results. I had 2 done last week
for $175 for both. Almost invisable and stronger than original. I
will send you some photos in a day or so.
fins,<SNIP> I need to get Allan Woodcock's number I guess.
Look no further than Allan's! His trim is not stainless (Hugh does
the stainless), it's an exact reproduction of the correct original
extruded aluminum as from the factory. They are top shelf items at a
reasonable price. Finally a quality part at a super price! Call
Allan at 310-466-6288
John Bevins
<table>Well I figured two things out: There were SUPPOSED to be two sets of snaps near the back of the
convertible top to keep the flapnear the zipper from flapping around. I was asking aboutwhat I
thought would be extra snaps there, but there are supposed to be some there in the first place.
I'll have to add those.
I got a marine light pole socket from Gordon's but apparently that was not the problem. There must be
some copper piece missing from around the bottom of thelight pole itself. Mine has that pointy prong contact on the bottom and then the other contact is a little 3/8 inch strip of copper inbedded in the black
plastic that will not make contact with the socket. There must have been some more substantial springy copper contact or something that was part of the the light pole base to allow it to make contact. I guess
I'll have to figure out what that was.
Jim Bihari
