Bihari, James
<table dir="ltr">
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">A few weeks ago I got my engine back from the engine guy and have had the car out in the water a few times.<span style="mso-spacerun: yes"> </span>It’s a lot of fun but I have a few questions:<span style="mso-spacerun: yes"> It's a long list but I'll gladly accept answers to any</span>
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><span style="mso-spacerun: yes">of thequestionsanyone might choose to answer.</span>
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><span style="mso-spacerun: yes"></span>
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><span style="mso-spacerun: yes"></span>(My car is a 1964, so I guess it’s an earlier style.)<span style="mso-spacerun: yes"> </span>Jim Bihari (bihari.1@osu.edu, toll free 866-487-7211)
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><xml:namespace prefix="o" ns="urn:schemas-microsoft-com
ffice
ffice"></xml:namespace><o
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">I’m going to email this to Gordon’s as well as the yahoo list in case anyone has any suggestions.
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><o
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">1. The engine guy took all my tags off of all the wires.<span style="mso-spacerun: yes"> </span>There is a blue wire with a female spade connector on the same group as the two (brown and large black) that go to the generator, and that blue wire is just laying there not connected to anything.<span style="mso-spacerun: yes"> </span>Everything seems to work.<span style="mso-spacerun: yes"> </span>Can someone look at the generator in their car and trace the wires back until you see a third blue wire that branches off and tell me where that wire is supposed to go?
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">2. Rear marine light pole connection.<span style="mso-spacerun: yes"> </span>We have power to the socket to the marine light pole fits into and the marine light itself works, but the light doesn’t work when put into place, so there must be some problem with the way the pole fits into the socket.<span style="mso-spacerun: yes"> </span>We once found two tiny curved brass pieces on the floor and I wonder if they somehow fit into the socket or are we missing pieces for the bottom of the pole?<span style="mso-spacerun: yes"> </span>At the bottom of the pole, there is a pointed connection at the end and then there is a second connection imbedded in the black plastic but there is no way it will touch the ground connection of the holder.<span style="mso-spacerun: yes"> </span>What is missing from what piece?
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">3. Carburetor.<span style="mso-spacerun: yes"> </span>The rebuilt carburetor we bought has been trouble since we got it.<span style="mso-spacerun: yes"> </span>I’ve now used the car for about 7 days and 300 miles (one long trip in October) and gasoline always leaks out when you shut it off and it often backfires.<span style="mso-spacerun: yes"> </span>Also, it’s almost impossible to start with a few minutes of being shut off because the carburetor is flooded with gasoline.<span style="mso-spacerun: yes"> </span>This makes filling up at a gas station embarrassing because it won’t start after you fill it.<span style="mso-spacerun: yes"> </span>(It’s not vapor lock—I put in an electric fuel pump but don’t use it because there’s too much gasoline in the carburetor.)<span style="mso-spacerun: yes"> </span>The engine guy said that the needle valves are not shutting off and this is why it leaks gasoline and floods.<span style="mso-spacerun: yes"> </span>I heard others say that some gasoline leakage is common, but can you guys start your cars after they’ve been shut off for only several minutes?<span style="mso-spacerun: yes"> </span>Does Gordon’s have new carburetors yet?<span style="mso-spacerun: yes"> </span>I’d like a get a good one or have this one rebuilt properly.
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">4. Source of water leaks.<span style="mso-spacerun: yes"> </span>It sure seems like this car takes on my water than it should.<span style="mso-spacerun: yes"> </span>We had EVERYTHING off of this car body and had it up on a rotisserie where they welded shut one hole in the rocker panel and filled some pinholes under the battery tray with fiberglass.<span style="mso-spacerun: yes"> </span>The (new) boots (steering, axle, emergency brake) seem good.<span style="mso-spacerun: yes"> </span>I know it leaks a tiny bit around the doors and front hood seals even though those are all new.<span style="mso-spacerun: yes"> </span>I’d say we use the bilge pump for 15-20 seconds every five minutes in the water.<span style="mso-spacerun: yes"> </span>I tested my two bilge pumps—one fills a 4-gallon bucket in 30 seconds, the other pump (which I don’t use much) fills it in 60 seconds.<span style="mso-spacerun: yes"> </span>So I’d say, it must be taking on about 3 gallons of water or so every 5 minutes and I cannot figure out where.<span style="mso-spacerun: yes"> </span>I had the rear seat out and was trying to see if it was coming in around the axel boots but they looked fine.<span style="mso-spacerun: yes"> </span>What is typical for water leakage and where can that much water leak in?
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">5. The three bolts that hold the exhaust pipe on the manifold keep coming loose and no one seems to have that triangular gasket (Gordon’s and NAPA didn’t have it, so we made a temporary one out of asbestos).<span style="mso-spacerun: yes"> </span>The loose exhaust allows the tail pipe to drop and you would think this could allow some leaking into the rear hole of the body where the exhaust comes out, but usually the exhaust outlet is above water, isn’t it?<span style="mso-spacerun: yes"> </span>Anyone find gaskets anywhere or have opinions about how to keep those bolts tight or know if much water would leak in there?<span style="mso-spacerun: yes"> </span>Thoughts about welding the exhaust pipe to the manifold to keep it in place?
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">6. We had a new top from Gordon’s put on by a professional top installer.<span style="mso-spacerun: yes"> </span>The first time we tried to put the top down, I forgot to unzip the side zippers.<span style="mso-spacerun: yes"> </span>We did not force it at all, but we really gentle and noticed it wasn’t folding up, so we opened it up and unzipped the zippers.<span style="mso-spacerun: yes"> </span>The zipper pull on my friend’s side completely came off the end of the zipper track when she tried to unzip it.<span style="mso-spacerun: yes"> </span>I got it back on, but now I need some kind of staple to put across the zipper track to keep it from coming off all the time.<span style="mso-spacerun: yes"> </span>Also the bottom of each zipper track is starting to tear the top fabric.<span style="mso-spacerun: yes"> </span>Even before this happened, the top installer guy pointed out that the zippers on the new top do not go all the way down into the double thickness fabric like the original top so they are more likely tear away.<span style="mso-spacerun: yes"> </span>This was the more expensive top, and considering the cost of professional installation, I’d like to find a way to repair the torn area around the bottom end of the zipper.<span style="mso-spacerun: yes"> </span>Any suggestions for repairing a small tear in a brand new white top?<span style="mso-spacerun: yes"> </span>I was thinking of adding 1 or 2 snaps along the side at the back of the frame so that I could avoid zipping the zippers all the way shut and avoid stress on the torn area.<span style="mso-spacerun: yes"> </span>Any reason that it would be bad to add snaps (like the three snaps that are already on each side, only farther back near the zipper area)?<span style="mso-spacerun: yes"> </span>The bolt holding the base of the snaps to the metal frame would have to go through the top fabric about an inch from where the zipper is—any thoughts that that might make it tear a different place?
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">7. What does Double Clutch mean?<span style="mso-spacerun: yes"> </span>I find that shifting into 1<sup>st</sup>, 2<sup>nd</sup> or Reverse, even when I have the car completely at rest seems to result in the gears grinding.<span style="mso-spacerun: yes"> </span>Maybe I need to adjust the clutch to be more disengaged when I think the pedal is to the floor?<span style="mso-spacerun: yes"> </span>What gears are supposed to be synchronous?<span style="mso-spacerun: yes"> </span>Shouldn’t I be able to shift into all gears when stopped without hearing a grinding noise sometimes?
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">8. Last year I bought two of the chrome headlight rings (part 10-32-05) “Chrome replacement to the original rim.<span style="mso-spacerun: yes"> </span>“This is not 100% original, but fastens exactly as the original.”<span style="mso-spacerun: yes"> </span>I’ve had 4 or 5 people look at them and try to figure out how they fit, then scratch their heads and shrug their shoulders.<span style="mso-spacerun: yes"> </span>That spring clip pops right out and even if you solder it in place, there doesn’t seem to be any appropriate tab for it to clip behind.<span style="mso-spacerun: yes"> </span>Are the chrome rings Gordon’s are now promoting like the originals or the same as the ones sold last year and if so how do they fit?
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">9. How does your Amphicar handle going around gentle turns at high speeds (over 45—like gentle curves on freeways etc.)<span style="mso-spacerun: yes"> </span>I find that it seems like I end up making more of a polygon path than a circular path (turn the wheel a tiny bit, then straight, turn the wheel a tiny bit, then straight, turn the wheel a tiny bit etc.) due to the way the steering wheel seems to stick in place.<span style="mso-spacerun: yes"> </span>Is that normal for an Amphi?<span style="mso-spacerun: yes"> </span>Also, since the guys had the front wheels off the body to put it on the rotisserie, the steering wheel does not line up to properly show straight ahead.<span style="mso-spacerun: yes"> </span>That steering wheel doesn’t have a spline on it does it—isn’t it just a shear pin that fits in one location, so I’d need to adjust all the nuts on the steering linkage to get the steering wheel to indicate straight ahead?
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">10. Anyone want to make an offer on a set of 1147 .040 over pistons I bought on ebay for $50 (two identical, then 2 others each different) or a complete set of .040 over rings I bought from Advanced Performance Technology in CA for $66?<span style="mso-spacerun: yes"> </span>We ended up installing the set of .020 pistons we got from Gordon’s.
></o
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt">Thanks in advance to any answers to these questions.
<span style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: Arial; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Jim</span>
ffice
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
></o
