Rear Wheel Bearings
Propcar50
I've taken everything apart and removed the bearings. No problem. What concerns me is I took out more than I expected. Starting from the inside, I took out the grease seal, the inner bearing, 2 large washers, and the spacer. The outside had no surprises. I checked the parts book and saw no reference about the large washers. For that matter, it doesn't show the spacer either. Should I put everything back the way I found it? Thanks, Randy in Gaithersburg, MD
