Rear wheel Bearings
K
Ken ''KD'' Roy
Mike,
I've had good luck using the following bearings & seals.
The seals are a little thinner, but they work OK.
04-20-03 OUTER REAR WHEEL BEARING (30X62X23)
5206K/BCA OR 3206 DOUBLE ROLL
04-20-08 INNER REAR WHEEL BEARING (30X62X16)
206/BCA OR 6206
04-20-05 INNER REAR WHEEL BEARING SEAL
34X62X10(34X62X08) 13475 (CR)
04-20-09 OUTER REAR WHEEL BEARING SEAL
45X62X07(45X62X08) 224530(NAT)
45X62X07(45X62X08) 17754 (CR)
Till later.....
Ken Roy
Send and receive Hotmail on your mobile device: http://mobile.msn.com
T Rear Wheel Cylinders General Amphicar Discussion 0
L Rear Wheel Bearing Play General Amphicar Discussion 0
M rear wheel seals logic General Amphicar Discussion 2
M Rear wheel assy seals? General Amphicar Discussion 0
S Rear Wheel Lock General Amphicar Discussion 1
E Rear Wheel Lockup General Amphicar Discussion 0
J Rear Wheel Bearing Seal Orientation General Amphicar Discussion 1
