No condenser (or distributor shaft wobble issues), Chas, as the points &
condenser are replaced by the Pertronix igniter - although for the first
test drive on Sunday I did reinstall the points/condenser, but experienced
the same synptoms.
Sent: Wednesday, July 22, 2009 5:13 AM
To: lrsnpark@gmail.com
Subject: RE: [General Amphicar Discussion-t-20490] Re: Amphi Misses When
Warm
A new condenser should solve this. If that does not work, try a second new
coil. A bad condenser will give these exact symptoms, and can eventually
take out the coil as well. Even if you replaced these two parts before, try
a second new condenser, and a second new coil, and this should solve it. My
guess is the condenser, and not the coil.
Chas
Quote:
Originally Posted by Ken Chambers View Post
http://www.amphicar770.com/amphicarforum/images/techtwo/buttons/viewpost.gi
f>
Well, the carb does sit on an extremely hot manifold. Stupid design,
IMHO, making a one piece intake/exhaust manifold. The thick
insulating gasket under the carb helps a bit but there's still a lot
of radiating heat hitting the carb. A deflector shield would help.
It's possible the gas is boiling under very hot conditions but seems
unlikely in that you are able to reproduce the problem with each drive.
It has to be fuel, air, spark or maybe something mechanical. Sure
sounds more like an electric issue. You've changed most ignition
items but could have two bad parts. (rotor, cap?)
Any excess play in the distributor shaft indicating a badly worn
bearing or drive gear? It was mentioned earlier but how about the
engine ground connection or even the distributor to engine ground
resistance.
Do check this. The ground strap on the moving vacuum advance plate
(the plate that holds the points).
Did you ohm out the circuit from coil to ignition switch (it goes
through the timer relays). Or hot wire the coil to the battery during
the problem. Run the engine in pitch darkness to look for jumping
sparks. Pull individual plug wires to isolate cylinders.
Try Click and Clack the Car Talk Guys on Sunday morning PBS. Might be
a first for them dealing with an Amphicar. LOL
---Ken Chambers
On Jul 21, 2009, at 4:44 PM, LSolheim wrote:
