So my car died randomly a few times this past summer "shakedown" season -
Worked fine in Celina - but in Port Clinton, a new thing happened - started starving for fuel, and then quit - wouldnt start. Couldnt figure out what happened - plenty of gas, was working fine, then suddenly starved out.
Some of you may know that rather than install an inline electric fuel pump to force fuel in case there was vapor lock, I took the advice of Gord Souter, who recommended a simple manual "primer bulb" from an outboard motor fuel line. Fuel flows thru, and prevents accidentally leaving a fuel pump "on" that could overwhelm the mechanical fuel pump, etc. Anyway, I installed it in the (ethanol-proof) rubber fuel line under the footboard, ...behind a trap door under the passenger side rubber mat.
So it occurred to me to open the trap door and take a look: lo and behold, the black rubber primer bulb was collapsed- sucked flat!: the manual pump on the motor was clearly doing its job "asking" for fuel... but something was not delivering it...and the bulb was the perfect visual aid to see that! ( thats another great point about the primer bulb!)
The fuel tap was open...the fuel filter flowed...the only thing left was the 12VDC fuel shutoff-valve.
It "seemed" to be clicking,,,but now it just wouldnt pass fuel! So I bypassed it with a double ended barbed brass coupler...and good to go!
John Bevins mentioned awhile back that the correct location that the factory derives 12v for the magneto is at the brake light switch. So i need to check to see if that supply connection is "100%", or if its funky - dont want to buy a fuel shutoff if not necessary.
>>> Have any of you folks ever has this happen?: the fuel shutoff valve works for a time, then after awhile shuts off on its own when you're out on the water?
>>>.Do the coils or connections in these eventually become "weak" or corroded?, allowing the valve to shut off and strand you?
Stranded a different way! #@
This one was much more abrupt - driving along at 1/3rd throttle on the water...Dashboard suddenly goes dark and the engine stops. Turn the key. Starts up and continues fine, again wiothou problem for a sew more days.
Then it happens again - lights go out, car instantly dies!
I found the answer - do you have a guess as to what it was??
