ATTENTION AMPHICAR OWNERS!
We have lowered our prices on the following parts. Please make a note of them in your catalogs.
Part Number Description Old Price New Price
4-20-24B Rear axle spline boot $ 23.31 $19.95
6-22-36a Tension spring $ 7.65 $ 6.55
8-28-02HP HP Exhaust pipe $112.15 $92.25
10-32-43B Back-up lens seal, black $ 19.90 $ 9.25
10-32-43G Back-up lens seal, gray $ 19.90 $ 9.25
11-35-22 Front bumper bracket, left $ 67.61 $47.50
11-35-23 Front bumper bracket, right $ 67.61 $47.50
11-40-12 Tension spring $ 7.65 $ 6.55
11-42-35 Return spring $ 15.44 $ 6.55
12-45-39 Gray rubber cover $ 56.65 $49.95
Weekend Specials
Good Saturday, Sunday, and Monday Only!
April 5th, 6th, and 7th
2014
PART # 10-33-37b/f/k SET
MASTER WIRE HARNESS RENEWAL SET
$425.00 EACH SET S&H $25.00 EACH SET
For those with multiple wiring problems, do we have a deal for you! Over the
past 45 years, wires can become faded, brittle, cracked, and broken. Not to
mention wires that have been cut and spliced, often with the wrong color. Well,
here’s a way to fix all that at one time. This special includes the main and rear
harnesses, as well as the common feed harness for the instruments. That means
you get basically all the wires for the car, front to rear! And to make it even
better, you SAVE a whopping $137.34 on the set this weekend!!
ORDER NOW!!!
PART # 11-34-33/48 KIT
DOOR WEATHERSTRIP SEAL KIT
$71.05 EACH KIT S&H $6.95 EACH KIT
Stop those door water leaks! You get both the door and body-at-door seals
(enough to seal one door). Best seal deal of 2014!! SAVE $25.00 per kit!!
ORDER TODAY!!! TIP: Check door leaks the simple, fast way . . . on dry land.
After adjusting your water lock handle stop, spray water on your closed door all
along the gap between door and body. Have someone shine a flashlight inside the
4 inch holes below the inside door sill area. (You may have to peel down the
rubber mat glued to the inside sill area first.) If water rushes past the seals, it will
roll over the white plastic strip. If it’s a small leak, it will flow down through the
three small holes on top of the door sill. Just shim your seal on door with thin
rubber strips (like inner tube rubber) to tighten fit against both seals. Also, be
sure your water lock handle is adjusted tightly against the stop and actually pulls
the door in towards body. Use 3M Weatherstrip Glue for best adhesion.
PART # 6-22-22x2 SET
FRONT BRAKE HOSE SET
$100.95 EACH SET S&H $5.95 EACH SET
Front flexible hoses on sale! Why not get them now and SAVE over $33.50!
Life is good!! ORDER NOW!!!
PART # 6-22-36x2 SET
REAR BRAKE HOSE SET
$65.95 EACH SET S&H $5.95 EACH SET
So, you only need the rear ones. Now is your chance to renew them and SAVE
over $21.00 in the process! How can you say no?!! DON’T DELAY!!!
PART #11-36-42
LEFT DOOR CATCH
$26.95 EACH S&H $3.00 EACH
Bang, thump, clunk. Year after year, the door slams shut, cutting grooves and
slide marks on the catch. TIP: Adjust your doors using your old catches as
“sacrificial” substitutes. Then when all is correct, install your new catches.
Extra Tip: Polish your new catches to a mirror gloss finish and spray with clear
gloss spray! SAVE $8.54 this weekend!
PART # 11-36-42a
RIGHT DOOR CATCH
Same great price, same great savings this weekend!
PART # 11-36-43
DOOR CATCH SCREW
$1.39 EACH S&H $2.50 for 1 to 4 screws
Here is a small but important part that many customers have asked for. Just
think, you can’t hold your doors closed without them. Now you can have brand
new, shiny, zinc plated, correct oval head screws to hold the door catches to the
door jamb. SAVE $0.60 per screw this weekend!! ORDER TODAY!! (Two
screws needed for each door catch.)
PART # 12-46-11b/19b SET
BLACK BUMPER AND SIDE MOULDING RENEWAL SET
$179.95 EACH SET S&H $20.00 EACH SET
We’ve done this set in ivory. How about those of you who would like black
mouldings? Well, here is your chance to renew both side mouldings and the rear
bumper all at the same time. And with the same great SAVINGS of over $55.00,
how can you go wrong?! DON’T DELAY!!
PART # 10-32-33cx6 KIT
CHROME HORN SCREW KIT
$2.70 EACH KIT S&H $2.25 EACH KIT
Brand new, shiny stainless steel! You mean I get stainless steel and a
dramatically reduced price? You bet! For those of you with a working horn,
but crusty screws, this is the kit for you. They will never rust again. Just
remember, don’t undo the 2 screws at the 3 and 9 o’clock positions until you
have the horn out of its body. And now for the savings on these polished
beauties. The old price has been slashed from $0.89 each to $0.59 each. But
this weekend, there is an additional $0.84 SAVINGS on this kit of 6 screws.
Plus, you get a complimentary pair of nuts and lock washers to complete the
package. DON’T MISS OUT!!!
PART #H-1 (WHITE), H-2 (RED), H-3 (BLUE), H-4 (GOLD)
AMPHICAR HATS – YOUR CHOICE!
$11.50 EACH HAT S&H $6.95 for 1 or 2 hats
SPRING IS HERE! It’s time for a new hat. ORDER NOW!!
VISIT OUR WEBSITE!
www.gordonimports.com
Please note: All shipping and handling charges are based on one piece/kit purchases.
Most likely, multiple parts orders will have reduced shipping charges.
Don’t forget. See our month long printed monthly flyer special for more
unbeatable prices!
Note-Weekend specials cannot be combined with other specials.
Improving Amphicar with 21st Century Technology.
ORDER NOW!!!
Order by Phone (leave message):
562-802-1608
714-523-3512
Order by Fax: 562-404-1904
Order by Email: sales@gordonimports.com
Weekend Specials
2014
ORDER NOW!!!
REAR BRAKE HOSE SET
PART #11-36-42
LEFT DOOR CATCH
PART # 11-36-42a
RIGHT DOOR CATCH
PART # 11-36-43
DOOR CATCH SCREW
VISIT OUR WEBSITE!
unbeatable prices!
ORDER NOW!!!
562-802-1608
714-523-3512
