Tech tips
Canadian four amphs
Todays tip.
installing tops.
I have always marked the holes with pencil then taken top and hole punched the area out then put back on car..
Today I used a elec. solder gun tip to melt threw and make a good round hole right on the car. save 12 steps ,as Henry Ford says..12 steps buy all his workers a day ,, means more money in his pocket.
Gord
Canadian four amphs
Radials
More and more people are putting 185/70..13 tires on the Amphicars. The handling is improved alot and tire presure can be raised. Problems begin in the rear tire area for space thou, they are very close to rubbing on wide springs or scoreing on the cable tab on swing arm,I now sell Alu. or steel spacers that move the tire out 1/4 inch but they can somtimes still be close,
the next step is to take a hammer and -hit to bend -the tab away from the tire a bit, and/or grind a bit off the bottom of the tab,Check for clearances as you turn the tire. also check that it will not hit the outside fender of the car,Some people do not realize that the tire area of the body bulges out, when they put new metal in, and loose this clearance,,
Make sure you mesure this with and record before you start taking body apart,I am going to add 1/2 inch on cars I do to help with clearance here.
A car in the shop right now(I did not do metal work) has the clearance of a thin Quarter , less than a 1/8th inch. I had to move the spring in a bit and use a thinner spacer to make it work.
Gord S.
azpaul50
This is definitely good advice as I just had a round of musical tires changing involving both my Amphis. One came with P185s and seemed okay but I didn't know that it had wheel spacers all around. When I upgraded my tires on the other Amphi to P185s (from P165s), I immediately ran into the rubbing problem on the rear wheels with actual contact only on one side and near rubbing on the other side. So, I installed the spacers. Then, for some unknown reason or maybe I didn't notice during the first evolution), the front wheels now rubbed when turned almost full throw. They hadn't done that before. So, I also installed a set of spacers on the front and all now seems well. In neither case do the tires hit the fenders but it is definitely close with only about a 1/4 inch clearance. While normally I'd say to avoid all this hassle by staying with the original smaller tires, the difference in ride and stance is substantially better. - azpaul50
To: azpaul50@hotmail.com
Subject: RE: [General Amphicar Discussion-t-20666] Re: Tech tips
Date: Thu, 14 Jan 2010 08:22:26 -0500
Radials
Gord S.
Hotmail: Powerful Free email with security by Microsoft.
http://clk.atdmt.com/GBL/go/196390710/direct/01/
Difference tires of the same posted size will differ in the width of their widest areas. Some simply work better with Amphicars than others. I believe the current Firestone's work fine.
azpaul50
Hey, Juanito! All I know is that I ended up putting tires of the same size from the same manufacturer (Hancook) on both cars. I would assume width differences would be due to pressures. Don't they use the same molds? - Pablo
Date: Thu, 14 Jan 2010 12:09:19 -0500
Your E-mail and More On-the-Go. Get Windows Live Hotmail Free.
http://clk.atdmt.com/GBL/go/196390709/direct/01/
No, manufacturers don't use the same molds. Very small car to car variations, sure, but I have trouble believing that the Amphicars vary much in spacing of the critical suspension and lower body parts. If they did the replacement parts wouldn't fit or there would be various versions of these parts in the parts book.
azpaul50
So the cause is putting tires on that were never intended to be used at that P185 80 size. I did notice one difference between the sets (of the same size), one was the "Shadow" series and the other doesn't have that designation. So indeed the same molds weren't used. - az[aul
Date: Fri, 15 Jan 2010 15:30:20 -0500
Paul,
I checked and I'm using Firestone P185 tires that had wide whitewalls bonded on and have a half inch of clearance from the large rear springs and more from the fender well. I've had no problems with clearance on either of my late model Amphicars. One thing to note though is that bracket that holds the brake lines, in the rear, can be twisted when tightening the pinch bolt and the way it's twisted varies the clearance from the rear tires to quite a degree. Be sure you have it twisted away from the tires. Also, if you have clearance problems with the fronts, the steering gear stoppers can be adjusted to fix that, though I've never needed to do that with my cars.
_____
Sent: Friday, January 15, 2010 12:30 PM
To: edprice@cox.net
(snip)
Assuming that the car company felt they could afford the luxury of full
documentation.
Documentation on my Benz is a study in Teutonic overkill, but IWK, at the
far other end of the industrial continuum, wasn't spending money on
illustrators and manual writers. Un-documented and semi-documented
variations abound in the Amphi world (rear bumpers, rear axles, bilge plugs,
wiring, suspension, shift linkage, paint, chrome all come to mind).
El Cajon, CA USA
WB6WSN
1961 Amphicar
1987 MB 420SEL
azpaul50
Hey Ed. Has it started to rain over there yet? We're expecting like 3 fronts to pass through there (coming here) starting Monday. Yeah, the documentation is a bit sparse. Another thing I notice is that John F. is referring to his late-model Amphis where both of mine are among the oldest of the oldies. Documentation usually evolves with the car.
Date: Sat, 16 Jan 2010 11:24:44 -0500
_____
To: edprice@cox.net
(snip)
documentation.
El Cajon, CA USA
WB6WSN
1961 Amphicar
1987 MB 420SEL
A IAOC Tech Tips for Jan/Feb 2006 General Amphicar Discussion 0
Midwest Amphicar Transmission Tech Session at Gators Amphicar March 21st + lunch General Amphicar Discussion 5
D Great automotive tech site. General Amphicar Discussion 1
B Club Newsletters: Tech Topics Index 2001-Present General Amphicar Discussion 0
P Aquada the new Amphicar from Gibbs Tech Launched today General Amphicar Discussion 0
A Extra seat from Colo to Celina - Tech Session topic? General Amphicar Discussion 0
E Convention Tech Sessions General Amphicar Discussion 1
M Tech Session/Thanks Billy General Amphicar Discussion 0
D tech session General Amphicar Discussion 0
D Tech Session Poll General Amphicar Discussion 0
D Tech Poll General Amphicar Discussion 0
C Celina tech... General Amphicar Discussion 0
B Celina tech on clutch chatter General Amphicar Discussion 0
A Celina Tech Session Requests General Amphicar Discussion 0
E Amphicar Celina Tech Sessions General Amphicar Discussion 3
B Celina Tech Sessions General Amphicar Discussion 2
D Celina Tech Session General Amphicar Discussion 6
D Tech Seminar for Celina General Amphicar Discussion 2
M Tech Question General Amphicar Discussion 1
M Tech articles General Amphicar Discussion 3
P Tech query-timing General Amphicar Discussion 0
R Tech questions for Billy Syx General Amphicar Discussion 0
G Double lipped seal install tips General Amphicar Discussion 0
Steve Looking for ignition trouble shooting tips General Amphicar Discussion 6
P Tips on Removing Logos? General Amphicar Discussion 6
jfriese Tips For Installing The Convertible Top General Amphicar Discussion 3
A Standing Water Tips General Amphicar Discussion 0
B Amphicar Universal/Replacement Parts Tips General Amphicar Discussion 0
A Tips... General Amphicar Discussion 6
A Standing Water Tips (Re-post) General Amphicar Discussion 0
W Amphi service tips. General Amphicar Discussion 0
S Color codes and paint suggestions and transport tie down tips General Amphicar Discussion 2
M Engine Tips General Amphicar Discussion 2
T Tips on inserting axles General Amphicar Discussion 2
A Strapping good tips General Amphicar Discussion 0
K Headlight maintenance tips General Amphicar Discussion 0
C SS Tips-n-Tricks General Amphicar Discussion 0
A Restoration Tips and Progress (lack of) Report General Amphicar Discussion 0
A Amphi Medical Tips: General Amphicar Discussion 0
