Hi Gord
I have a rusted headlight bucket. Want to replace both what do you have to
replace them and do I need new hardware etc. Let me know what I need and the
price.
Brian
Sent: Friday, September 17, 2010 7:03 AM
To: Brian Faherty
Subject: RE: [General Amphicar Discussion-t-20882] Re: Installing brake
hoses
Front Flex hoses.. first step is to put a Thread sealant(LOCTITE 565) on
each end, install banjo fitting on one end tight but not supper tight,
install other end in wheel cyl., If it is not laying straight,you can try
restarting it, do not overtighten wheel cyl end or you will break the
housing(been there, done that)
If needed try tightening the banjo a bit or off a bit to staighten out flex
line.
Brake flex lines should be changed every 10 years, Originals should never be
reused as they colapse in the inside, you can push the fluid threw but it
will not return holding brakes on.
I stock fronts for Amphicars($38.oo) and rears($28.oo)you should also change
the rear steel line into cyl.
GORD S> Canadian Amphicars.
