I installed mine a couple of months ago with no problems. With the front end up off the ground, the front suspension should be fully extended, you should have to slightly lift the wheels to fit the shock-spring. Mine is an early chassis, the layout on later model Amphicars are different, and use different shocks and springs. Could that be the issue?
Craig in Alviso
