Have you posted the part drawings for the shock spring adapters ? If not could I get a copy of them ? I use Solidworks so you can send them in SolidWorks format. My Email Address Is Tony@ortakales.com
Thanks
Tony In NH
Thanks
Tony In NH
I did take before and after measurements at the wheel well height for the custom collars that I had built. After the install there was no difference. The car has the same stance.
In response to a few of the other threads.
Is there (or was there) a coil-over version of the Maeco PK22K1?
Not that I am aware of. There use to be. In order to use the PK22K1 shocks you'll need to have a set of custom collars made.
Can I put my Amphi springs on the model being offered now?
I modified the cad file last night to see how tight of a fit it would be. The original Amphicar spring id is fairly close to the od of the shock. The Maeco shock buldges out at the bottom of the shock to hold the orignal collar. While it could be done personally I would not be comfortable with how thin the wall section would get on the collars that would be needed. So I believe the answer is no to being able to use you original springs with the Maeco shock.
Should you want a softer ride for some reason Ken is correct in that Summit Racing has lighter springs as well. The id of the custom collar may need to be adjusted for it.
