Ted:
You found that faster than I found it on my machine! <g> I don't mind anyone
quoting one of my old posts. BTW, for anyone who is zealously interested in
measuring spring rates, I have a set of photos showing the technique using a
strain gauge and a hydraulic press. Just email me for it at edprice at cox
dot net .
El Cajon, CA USA
WB6WSN
61 Rust Guppy
1987 MB 420SEL
Sent: Friday, July 31, 2009 12:41 PM
To: edprice@cox.net
Subject: RE: [General Amphicar Discussion-t-20515] Re: Amphi Shocks -
http://www.amphicar770.com/amphicarforum/images/smilies/dft012.gif> I
found this data in the archives from 2003, so I hope Ed doesn't mind me
re-posting it. These are his research numbers comparing Amphicar shocks and
springs to the Maeco. They look pretty similar to me!!
Ted
www.amphicar770.com/.../16316-front-suspension-spring-rate.html
http://www.amphicar770.com/amphicarforum/images/techtwo/statusicon/post_old
.gif> 11-05-2003, 04:24 AM
Posts: n/a
Front Suspension Spring Rate
I finally got around to measuring the spring rate for my Amphi front coil
springs. I also measured the rate for a new Maeco PK22K1 coil-over shock
(available from Surplus Center at $20 each). Here's the results:
For 1 inch of compression:
Original Amphi Front Spring #1: 172 pounds
Original Amphi Front Spring #2: 145 pounds
Maeco PK22K1 Shock & Spring: 180 pounds
For 2 inches of compression:
Original Amphi Front Spring #1: 350 pounds
Original Amphi Front Spring #2: 304 pounds
Maeco PK22K1 Shock & Spring: 310 pounds
Averaged out, the spring rates for each are:
Original Amphi Front Spring #1: 175 pounds per inch
Original Amphi Front Spring #2: 152 pounds per inch
Maeco PK22K1 Shock & Spring: 155 pounds per inch
I conclude that one of my front springs is a bit weaker than the other. I
also
see that the Maeco is very similar to the original Amphi springs. So, I'm
going
to follow Ken Chambers advice and use the pair of new Maecos on the front of
my
Amphi.
BTW, the Amphi shocks have an extended length of 13" and a stroke of 3.5".
The
Maeco shock has an extended length of 13.25", and a stroke of 3.5". This is
so
close as to be identical.
Rear spring data maybe next month.
