Larry:
Have you measured the input voltage to the coil when first starting up
(idle, but engine fairly cold) and then when the engine has been missing?
That comment about the miss being worse when the headlights are on makes me
worry about the voltage level to the ignition system. Turning on the lights
will drop the voltage a bit, and if it's low voltage that's causing the
ignition miss, then turning on the headlights would be expected to make the
miss worse.
And if low voltage is the problem, then the odd part is why the low voltage
is temperature dependent!
El Cajon, CA USA
WB6WSN
1961 Amphicar
1987 MB 420SEL
_____
Sent: Saturday, August 22, 2009 3:33 PM
To: edprice@cox.net
Subject: RE: [General Amphicar Discussion-t-20530] Re: Lake McMurrray
Swim-in
Re-routed the fuel line per Dave's suggestion and even ran the 5/16 hose
inside of a piece of 5/8 heater hose to act as insulation. Also disconnected
the generator and launched out on a 45 minute test drive/swim. All went well
until the final leg home she she began missing again. Seemed like it got
worse when the headlights were turned on, but there was no generator load
involved. Some sort of voltage leakage when hot?
I checked the coil & generator by touch about 1/2 way into the trip (no
symptoms at that point) and all was fairly cool. After limping into the
boathouse they felt quite a bit hotter, but not as much as the other day. I
did not hear any fuel boiling from the carb today.
I will proceed with the alternator conversion next week. Meanwhile, please
think of me!!
All of your thoughts and ideas are greatly appreciated.
--Larry
miss worse.
El Cajon, CA USA
WB6WSN
1961 Amphicar
1987 MB 420SEL
_____
To: edprice@cox.net
Swim-in
think of me!!
--Larry
