Help needed with Amphicar Water trans gears.
Jacques B.
Guys,
Need some help here. I opened my water trans and found that one of the gears had a lot of play internally, in between the “Hat” and the gear itself. Upon the disassemble I found that in the past they have replaced the needle bearings by a bronze sleeve. Anyway, I discovered that both of the water trans gears have the same size. I believed that one was suppose to be smaller than the other one? Or different anyhow? Both are exactly the same. Is possible that some amphicars came with both gears exactly the same? If not, may be that’s why the bronze got eaten? They replaced a bad gear trans with another one that was the wrong one (bigger) and if forced the system, so the bronze sleeve got eaten? What you guys think?
Any help will be much appreciated.
Jacques B.
Thanks foir the reply Cameron, but in my case I don't think so. What I'm thinking is that they substitued one of the gears in the past for a reconditioned one, but it was the wrong size. Both gears are the exact same size, and I heard that they were suppose to be one smaller than the other (kinf of 2 mms or so). I got one refurbished small gear, and when I test play before mount on the case, if I put the smaller gear on the left of the case and the bigger on the right, it gets loose. If I invert the gears (smaller on the right and bigger on the left) both fit perfectly. So I suppose they assembled the box with two big ones, and it got forced, so that's why the bronze got eaten so bad.
Here some pics:
F "Amphicab" Urgent Help Needed General Amphicar Discussion 2
Midwest Amphicar Tavares Lake Harris ramp help needed General Amphicar Discussion 3
D Parts help needed rear reflectors General Amphicar Discussion 3
D Really a 63? German help Tires needed reproduction tags General Amphicar Discussion 4
R calculation help needed General Amphicar Discussion 1
L Shock Problems - Spring Help Needed General Amphicar Discussion 1
D Tranny Help Needed General Amphicar Discussion 1
C Help Needed General Amphicar Discussion 9
B U-joint help needed General Amphicar Discussion 1
M Water tranny help needed General Amphicar Discussion 2
M Pole light help needed General Amphicar Discussion 0
DougFromBaltimore Convertible top - Help with weather-strip over side windows General Amphicar Discussion 4
S Newbie ... help me find a car please? General Amphicar Discussion 1
Jon March gauges - any help appreciated General Amphicar Discussion 1
Jon March searched for an hour- cant find the answer- help? General Amphicar Discussion 1
Jon March Alternator wiring help please General Amphicar Discussion 10
Jon March we could all use help with this Amphi issue: General Amphicar Discussion 0
Midwest Amphicar Carb or ? help General Amphicar Discussion 5
Midwest Amphicar Printed knobs help General Amphicar Discussion 0
Midwest Amphicar Help identify this magazine General Amphicar Discussion 0
Midwest Amphicar Temp gauge help General Amphicar Discussion 6
J help with mounting new upholstery General Amphicar Discussion 3
Ed Price RE: Help with posting to the e-mail list General Amphicar Discussion 0
Midwest Amphicar I need help in Mesa/Phoenix General Amphicar Discussion 1
auburnamphi Help with horn General Amphicar Discussion 9
Midwest Amphicar Celina extra bed/ floor ....Help General Amphicar Discussion 2
H help? !???! General Amphicar Discussion 1
auburnamphi need some help General Amphicar Discussion 5
Tom Laferriere Help with Wiper Blades and/or Arms General Amphicar Discussion 27
auburnamphi Help with weatherstrip General Amphicar Discussion 7
D Shipping help - Monticello Mn to Illinois General Amphicar Discussion 0
R Original Horn Help? General Amphicar Discussion 2
C Fwd: Anyone near Lancashire, UK who could help with transport to the port for... General Amphicar Discussion 1
D 1300 Cam Help General Amphicar Discussion 3
L 1300 help General Amphicar Discussion 15
B Maybe fellow water lovers can help General Amphicar Discussion 0
R Need help - How to flash my generator General Amphicar Discussion 0
B Wiper Help General Amphicar Discussion 3
D electric fan help General Amphicar Discussion 1
R Help identifying clunk General Amphicar Discussion 1
D Parts help!! General Amphicar Discussion 0
S triumph window fuzzies.........HELP General Amphicar Discussion 2
T help with picking up Amphi General Amphicar Discussion 0
A can anybody help? how to convert konvensional car to amphibian? General Amphicar Discussion 5
D Great Son -Museum/restoration help wanted General Amphicar Discussion 0
C Can anyone help me? General Amphicar Discussion 4
D help with axle idea ---- Great book General Amphicar Discussion 2
