door panel springs
rayhand
There are two springs of different sizes for the door panel. Which springs goes on the door handle & which spring goes on the window crank? Thanks Ray
Good day! Two springs go on the window cranks, Ray. The larger, straight-sided spring goes under the door panel (with a felt/leather cushion or protector between the spring end and the door panel material). The tapered spring goes inside the 2-piece rosette assembly to keep the inner ring pushed out covering the attachement pin. Good luck.
