Clutch Alignment Tool
Can someone suggest the type and size clutch alignment tool to purchase? I just bought the new Friese Clutch Kit, and will need to use the tool. My local auto parts stores have many types and sizes. Just not sure which to buy. Thanks, Doug
What I did was to remove the bell housing, bolt the clutch & pressure plate loosely on the fly wheel, slide the transmission into the engine, tighten down the pressure plate bolts, remove the transmission, reinstall the bell housing.
It's a standard 24 spline clutch alignment tool for air cooled VWs, Dasher, Thing, Fox, Porsche 256, 911 and others
Mine is a PLEWS 73-351 but I can no longer find a reference to that brand. EMPI 5302 is an identical tool.
My mechanic in 1968 used a ground down VW pilot tool.
Three cheers for Hugh Gordon! I met him at Ranchero Motors in 1978. Hugh had just had his Amphicar overhauled in Mexico. Before Gordon Imports, I used to import Amphicar Parts from Bert Story Glas concessionnaire in Rhenoy, Holland.
i like the strandweis way bolt and socket but years ago i had a universal clutch allignment tool with different pilots and a tappered piece and worked really good. will just grind down the 7.00 one or get gordons and what ever works
