Carnut
Help: On test drive after reassembly, car shifts well and is smooth, except when I press in clutch in 2nd, 3rd or 4 th gear and car is rolling, i hear clicking sound from gear box clutch area, goes away when in neutral. Does not do it in 1st or reverse. Noise is same with engine off. Replaced clutch and throw out bearing before reinstallation . Also had inspected the universal joints before reassembly . Have checked clutch adjustment about 3/4 inch play in pedal. thanks
