Parts in Florida Fall 2024
I just went out and marked down all the parts I have in Fl. on the attached list the one with *** at end are what I have right now.
Part I have in NOV. will have a *** beside it!
Gord Souter
6823 Fern Cir
Leesburg, FL 34748
United States
gord@amphicar.ca gord@amphicar.ca
01-01-01v few valve springs used,,,,,,,,$5.00***
01-01-01bl lower gasket set $51.00
01-01-01t top gasket set $55.00
01-01-01w head gasket......................$20.00***
01-01-02 front motor frame for mounts.....$25.00***
01-01-06. Motor Mounts....................$35.00***
01-01-10 bell housing used...............$40.00***
01-01-20. battery ground strap $15.00***
01-01-20a carb return spring $2.00
01-02-36 OIL PAN GASKET $10.00
01-01-40 used dip stick...............$10.00***
01-03-11. good used flywheel...........$75.00 ***
01-03-23. new timing chain $20.00 ***
01-04-01.
01-04-02. carb linkage $10.00
01-04-02a new water pump supplyer raised price $125.00
01-04-16. used water pump housing...........$25.00 ***
01-04-31.. used thermostate housing.........$30.00 ***
01-04-32. gasket for thero..................$4.00 ***
01-04-25 FAN BLADE ASS, ENGINE $30.00 ***
01-04-29.sold Fan Belts $15.00
01-05-06. used intake................... $25.00 ***
01-05-15. oil filters big thread $10.00 ***
01-05-15a oil filter adapter thread must have this $10.00
01-06-01r replacement fuel pump with lever $70.00
01-06-01kit fuel pump kit.................................$65.00 ***
01-07-01. AMPHICAR CARBS,,rebuilt.exchange only! LIKE NEW2 styles aval. $400.00 ***
01-07-01a. Amphicar carburators,, repacement type $240.00
01-08-01. air filter ass. ....SOLD
01-08-03. air filter...................... $19.98
01-09-01, NEW Generator. no pully................$135.00
01-09-01A.sold NEW Altinator generator looks Original.$500.00
01-09-04 generator pully ass........................$60.00 ***
01-09-12. gen special mounting bolt................$12.00 3 ***
01-09-16 used ajusting arm.....................$10.00***
01-10-01. new starter..............................$$155.00
1-11-02u used dist bodys,,.......................$25-$50-00***
01-11-02. Electroncic Dist replacement for Amphicars,must be Neg, Ground $350.00
01-11-02 x Electronc dist inner part covert your dist..$170.00
01-11-16. Vacumme Adivance unit............$100.00
01-11-04. rotor Lucas $10.00
01-11-05. point and condensers $20.00
01-11-24. used orginal coils.............$20.00 *** NEW COIL screw in... $40.00
01-11-25.. coil end. $8.00
01-11-30. plugs.. #3.50
02-02-02misss miss. used trany parts and gear avall.***
02-14-05 trans. Mount. $70.00 have 1 with no threads***
02-15-07 Transmission Gasket $15.00
02-15-08. bolts 8'25 0.55
02-15-12 Alum base plate used parts are 1/2 price of new $250.00 ***
02-15-13 Base Plate Gasket of new $15.00
02-15-14 Base Plate Gasket $15.00
02-15-15 Dowel Pin $2.55
02-15-32 trany fill caps...2 $20.00***
02-16-37 2 roller bearings..............$20.00***
02-16-06 mid tran seal.................$20.00***
02-15-16 Water Transmission Case Rear $185.20 used ***
02-15-18 Water Transmission Case Gasket $35.00
02-16-48 2 big gears used......................$29.00***
02-16-49.. big gear main shaft.....................$50.00***
03-19-02 Taper Ball Bearing lower price $58.00
03-19-01R Rebuilt prop shaft ass. Exchange ready to go with gasket left or right $550.00
03-19-03u Propeller Drive Shaft main shaft in housing $399.00
03-19-04 Locking Circlip $1.69 ***
03-19-05 Cylindrical Roller Bearing $30.00***
03-19-06 Locking Circlip $5.50***
03-19-07 Washer $15.00
03-19-07.u washer,used $2.00
03-19-08 Spacer Washer $10.00
03-19-08u washer ,used $2.00
03-19-09 Oil Seal for Propeller Shaft old style, hard surface $5.00 ***
03-19-09a new prop shaft seals $12.60
03-19-10 Keyway $10.00
03-19-11. propeller 357.31 used 75--250..****
03-19-12. washer behind prop $11.00
03-19-13 White Propeller Hub Nut $43.00***
03-19-15 Popeller drive shaft ass.......$250.00
03-19-16 Oval prop housing gasket 2 squ. , $10.00 ****
03-19-19. lipped washer $1.00
03-19-22 prop shaft&u joint $250.00 for used ones ***
03-19-22kit U-joint repair kit for 1 joint $33.00 ***
03-19-23 special Allan bolts for prop shaft $1.25
03-19-24 tool tool for special allan bolt 3/8 drive.......$18.00
04-20-02 Locking Clip $4.39 ***
04-20-03 Outer Rear Wheel Bearing thicker one $59.00 ***
04-20-04 spacer behind bearing 03 $3.00
04-20-05 Inner Rear Wheel Bearing oil Seal $12.15***
04-20-06 Distance Bushing $14.00
04-20-07 Compression Spring Washer $23.00
04-20-08 Inner Rear Wheel Bearing $29.43 ***
04-20-09 Outer Rear Wheel Bearing Oil Seal $9.00***
04-20-11.. bolts for swing arms..........6 $5.00 ***
04-20-23. nuts for axle $9.00 5 ***
04-20-24a Early drive shafts Rebuilt..$450.00 (4) $550.00 2
used parts.. $100-200.00***
04-20-25 keyway $10.00
04-20-26 Rear Hub Used..$200.00 have 1 $495.00***
04-20-24 Wheel Hub Studs $3.50***
04-20-100 bolts to hold drum on..............$5.00 each***
04-21-16 snub axle $100.00***
04-21-28, front axle nut and special washer,,27..$10.00 ***
04-21-39 snub axle drop arm nos..............$25.00***
04-20-29... end shaft nuts.....................$10.00 ***
04-20-31 1 rear dust cap..................$10.00***
04-20-41. used early bellows..............$30.00 ***
04-20-43. GASKET FOR SWING ARM SHAFT $7.10 ***
05-21-09 Outer Brass Bushing $40.00 lots***
05-21-10 Inner Brass Bushing $40.00 lots***
05-21-16 Stub Axle $210.00 ***
05-21-17 2 king pin bushings
05-21-18/38 custom made for Amphicar with Radials keeps away from shock
05-21-18/39.sold Aluminum 1/4 inch wheel spacers $30.00
05-21-18a Front Spindle, Right Wheel $360 ***
05-21-19 gasket for shock top $5.00
05-21-20 Front Wheel Bearing Oil Seal $20.00 ***
05-21-22 Front Wheel Hub used$225.00 $500.00 ***
05-21-23 nut studs $3.50 ***
05-21-24 Wheel Mounting Nut $3.50 ***
05-21-25 Inner Front Axle Wheel Bearing NeW PRICE! $20 ***
05-21-26 Outer Front Axle Wheel Bearing NEW PRICE! $20 ***
05-21-44b-r rubber bear boots for front hub.................$30 pair ***
06-22-01 used backing plates brake..................$25.00 ***
06-22-08 steel line brakes rear...2...............$20.00***
06-22-14 used brake drums..........................$50.00 ***
06-22-15 New master cly. With proper internal piston $50core $110.00
6-22-22r hose front...............$35.00 each
06-22-29 support springs for brake shoes..........$15.00***
06-22-36. rear flex hose..........$35.00 each ***
06-22-37 long steel line............................$15.00***
06-22-42 Brake Fluid Container Used for $15.00 *** $60.00
06-23-26 Expanding Bar........$5.00 ***
06-23-26a Expanding Bar
06-23-29kit rear wheel cly kit(rubber,spring,holders,boot) $34.00 a side,, without new piston.. $22.00 ***
06-23-27 Tension Spring $10.00 ***
06-23-28 backing plate tension spring $10.00 ***
06-24-02 master cylinder brake rod........$15.00 ***
07-25-01 used steering box.................$120.00***
07-25-02 steering shaft u joint............$35.00 ***
07-25-48. bracked to hold steering shaft up used..$10.00 ***
07-25-23 used long tie rod ass............$30.00***
07-25-25 replacement tie rod ends 2 $25.00 ***
tie rod boots..... $8.00
07-25-81 powder coated used amphicar rims $200.00
08-27-02. fuel shut off, replacement.....$35.00
08-27-07 fuel sender gasket............$6.99..***
08-27-10aR Gas Cap Gasket .......... $10 ***
08-27-10 gas cap........................$15.00 ***
08-27-14 fuel shut off rod................$5.00***
08-28-02 used j pipe or just end............$10.00***
08-28-01 Muffler for Amphicar… need to be modifiedCan weld into original $75.00
08-28-02 U shaped exhaust pipe $85
08-28-03 nut for exhaust…1-14. $1.00
08-28-07 front bracket for mufflerSS $80.00
08-28-09 rear muffler bracket SS $80.00
09-29-03 old style heater blower ass used.......$100.00***
09-29-18 used heater core.................$90.00***
09-29-55 heater elbow...................$10.00***
09-29-34 used heater dash rubbers,, 2......$10.00***
09-30-22, used oil cooler ass...........$100.00 ***
09-30-26sold Lower Radiator Hose $25.00
09-30-27. rad hose clamps $5.00 ***
09-30-31. seal kit..40 ft a roll $40.00
09-30-37 Upper Radiator Hose $25.00 replacement
09-30-39. rad side brakets used.. 2...$10.00 ***
09-30-40 oil cooler lines exchange only $38.00 ***
10-31-27 Instrument Panel Metal Housing used for $40.00 ***
10-31-03 bulb holders $2.00***
10-31-04 small special bulbs from Germany $4.00
10-31-09 used speedo cable......................$20.00***
10-31-15K Knobs for all switches… Used,painted.$15.00
10-31-16 Dash Switch .no knob or rosett $20 ***
10-31-20 Propeller Dash Lamp $36.00
10-31-26k. SPEEDOMETER ...........$250.00 ***
10-31-31 used flashers.............$5.00***
10-31-40 gormet rubber o rings..........$3.00***
10-32-02 used headlight rings..........$10.00***
10-32-11 used headlight socket.........$6.00***
10-32-12 head light holder used.........$30.00***
10-32-16 nav light socket und front lends used...$25.00***
10-32-18. turn signal used clear....$5- $20.00 each..***
10-32-20 Dimmer switch replacement $28
10-32-22 home copper mesh battery ground strap $13.50 ***
10-32-35e Pin Contact Switch rear nav.lite $60.00 ***
10-32-36/52 other end see 40-14 replacements $25.00 $60NOS
10-32-36a small belt loop straps for nav light each $7.95 ***
10-33-11x ORIGINAL STYLE BATTERY BOX 3pc kit $130.00 $60.00
10-33-12 solenoid replacement $70.00 B/O
10-33-17 Terminal Block,1 pos. $1.57
10-33-18 Terminal Block,3 pos. $4.95
10-33-19 Terminal Blaock,2 pos. $3.29
10-33-34. terminal blok large.....$10.00
10-33-20 battery to Solinid main lead wire $16.00 ***
10-33-21 Solinoid to Starter strap, $16.00
10-33-23 Battery to body ground strap as Original 14 inches. Braided $17.00 ***
10-33-26/9 wiper arms used........................$5.00***
10-33-24r replacement 11 in wipers black $15.00
10-33-34. electrical connectors.................$10.00
11-34-100 used chrome blower cover...............$10.00***
11-34-13asold large style drain plug wing nut style $30.00
11-34-06c inner rear quarters in 18g steel NEW! left or right $260.00
11-34-06d sheet meat under battery or muffler.36 in. long w/beads left or right $165.00
11-34-06e inner tire fender from battery tray to front of tire inside, left or right $165.00
11-34-38. door rubber on body kit............$30.00***
11-34-25 hood rubber on body used...........$30.00***
11-34a-09c Quarter Panel, left rear Full fender w/fin $270.00 fibreglass
11-34a-09u Quarter Panel, right rear fibreglass now avail. reproduction
11-34-37new New.rocker panels with hump fibreglass 1 here..$75.00
in stock 18g steel $100.00 each have both here
11-34a-9SL&R STEEL quarter panels left and right .Rocker aval.a PAIR $1,000 Rockers$100
11-35-12. used rear bumpers................$70.00 ***
11-35-13 2 rubber seal for bumper.........$10.00***
11-35-22/23c front bumper brackets used one only...$25.00 ***
11-36-07 Door Lock Assembly,Left used $165
11-36-07a Door Lock Assembly,Right $165
11-36-13ba door handle rubbers 1 black $24.00
11-36-16. regulator for door windows......$170.00
11-36-28r/kit repro window cranks,with rosette $20.00
11-36-41. CLIPS for fuzzy strips $2.50each b/o
11-36-42,,,a door catches $29.90 ***
11-36-43 bolts for door catch. new product $1.00 15
11-36-44 water door stops $29.19 ***
11-36-47 door clip to hold panels on. $1.00***
11-36-48. door on door seal kit............. $100.00
11-36-51 4 pc kit alu top of door,,have clips and rear only rubber too. Clips are $1.00 each $150 kit
11-36-59 window post rear. custom made $49.20
11-37-10. 1 vent glass.................$35.00
11-37-20kit u chanel for 1 car............$200.00
11-38-13 used window rubbers.............$5.00***
11-38-21-23. .used.window cranks and rosettes..$5.00**
11-39-01b clip to hold hood rod 3.........$15.00***
11-39-06 hood key,, small.................$15.00***
11-39-07 front hood safty catch.........$15.00***
11-39-04/5 front hood locking units..used...$25.00***
11-39-11, front hood seal top............$79.00***
11-40-00 rear hood nave light base.........$70.00
11-41-01 Hand Brake Pull Lever Ass. $120.00***
11-41-04 used front cable $20.00***
11-41-14 used rear braket cable with rubber and triangle..$25.00***
11-42-01. lever clutch...................$40.00
11-42-04. lever brake....................$40.00
11-42-05. lever..........................$20.00***
11-42-6. new rod for pedal arms.........$18.00***
11-42-07 lock plate 2 holes..............$10.00***
11-43-03 alu shifter pivot................$100.00***
11-43-13 used shifter knob..............$5.00***
11-43-25. shift rod holder at trany.......$20.00***
11-43-33 used shifter boot...............$5.00***
11-43-35. Trany bracket..................$15.00***
12-44-07 water shift pivot at trany.......$20.00***
12-45-36. used alu, trm for back of top....$89.00***
12-45-39 grey side covers nos and used....$20-$40.00***
12-45-49 used white top...................$100.00***
12-46-02a rear reflectors used..............$5.00***
12-46-04 nose trim used...................$10.00***
12-46-03. right alu tail fin...............$125.0
12-46-21 very used AMPHICAR crests..........$20.00***
12-46-25 used exhast rubber seals............$10.00***
12-46-27a very used rear tail lite glass...$5-10.00***
12-46-28 used inside mirrors...............$10.00***
12-46-32. Radio delete plates..............$35.00***
12-46-35 very used hubcaps.............$5-10.00***
12-46-37. visors used and 1 good bracket.......*** $$$$
12-46-24 poor used exhast $10.00***
12-47-39a Tonne cover for cov,top dark red marron,, $140.00*** 1
12-47-43 tonne cover snaps $4.00
12-47-12, seat tracks.. have 1 originals..$200.00 each***
12-47-14a seat lock lever used............$50.00***
121-48-06 and 4. rubber triange and long strip under doors..$15.00 each***
12-48-17. Carpet Humps...................$20.00 each
12-49-01. tool kit......................$40.00***
12-49-03 replacement bilge pump./mounts same place $150.00
also have a inventory of bulbs for dash, and back up etc.
Trailer tiedown kit...... $165.00
radio delete kit.........$35.00***
headlight cap to hold ass, in car,$20.00 ***
auto float for bilge..........$35.00
bilge body drain .................$12.00 ***
bilge plug for above style drain...$28.00
Jack plates for under sides of car.....$70.00
carpet humps.................$30 kit
Rubber tiangles.............$20.00***
Amphicar parts manual repo pictures only// $ 30.00***
Amphicar repair manual repo..................$ 35.00/
in line gas filters... 6..$5.50 ***
1 seat hight ajuster and locks...$10.00***
1 trany dip stick...$8,00***
special rubber across rear seat bottom NOS.$60.00***
hog ring tool........$20.00***
miss. snap rings....*** $5.00
hose for brake fluid resivior... cut to length... $5.00***
