Wiper Switch
amphigr66n
Hello everyone: My wiper switch is totaly seized! I called Gordon
to get a new one. Guess what, they don't have any. Anyone out there
have one or know the part number for one at a parts store/dealer?
Thanks! Amphigr66n. Marc Struglia 817-489-2301
Michael Echemann
Take it out and work it a bit. These usually can be cleaned up and made
useable again.
Sent: Monday, August 30, 2004 9:38 PM
Subject: [amphicar-lovers] Wiper Switch
THE AMPHICAR-LOVERS LIST
Yahoo! Groups Links
Marc,
Mike is right, you can clean it up and have a good switch. The
following method can be used on most of the Lucas switches used.
- Pull the "C" clip from off the knob end. This keeps the post from
falling out the back.
- Pull the contact out of the back of the switch. If it is stuck in
there hard, soak it in a penetrating oil (I use "JB" brand
penetration fluid) overnight to loosen the rust. NOT WD-40! It is
not a penetrating oil.
- Once it is out, use 000 steel wool to clean up the contact block,
contacts and post.
- Re-assemble with a daub of dielectric grease on the contact block
face and you will have a good as new switch.
John Bevins
Rocky Mountain Amphicar
mstrug@juno.com
Re: Re: Wiper Switch
Mike, John: Too late... The side of the switch broke off. Any way I installed
a cheapie 2 pole switch for now and it works! The wipers 'park' also-they at
least stop on the down stroke. What are those other wires for? While I am
here, does the horn have a relay? I can not get a voltage at the wires to the
horn when I push the button. Fuse is O.K. Thanks! Marc Amphigr66n.
WB6WSN
Sent: Saturday, September 11, 2004 5:01 PM
Subject: [amphicar-lovers] Re: Wiper Switch
Marc,
First the horn. The horn gets 12 volts continuously from the battery
and seeks a ground return path to activate the horn. It gets this
return path through the horn button which connects the horn wire to
the metal steering wheel shaft. For some reason, one thing that is
pretty common to horn problems is a hard build-up of crud on the
contacts inside the horn. The horn is pretty easy to open up and
cleaning those two contact points might just fix that problem.
The wiper is a bit more complex a problem. There are three wires to
the switch. One is the 12 volt source, the other two run to the
wiper motor and supply power either directly to the wiper motor or
indirectly to the motor through an internal switch inside the motor
assembly. When you turn the wiper switch on it sends power directly
to the motor. When you turn the wiper switch off the power is
redirected to the motor through the internal switch inside the
motor. Therefore when you turn the power off the wiper will continue
to run until the internal switch opens and stops the motor. This
internal switch is positioned so that the wipers come to rest at the
bottom of their cycle.
The panel switch used for the wipers is electrically called a "single
pole, double throw switch" and is quite common. You should be able
to find some other switch that has this configuration and will make
your wipers work normally.
John:
When I was stripping my car down, my wiper switch was in such bad shape that I
didn't save it. However, when I look at the Amphi schematic (the big plastic
laminated one), I see that Switch 29 is actually a Double Pole Single Throw
(DPST) switch. In the Wipers OFF position, the Brown wire from the wiper motor
is grounded. When the switch is activated, the Brown wire is not connected to
anything anymore. However, the Red/Black wire from the wiper motor is now
connected to Fuse 4, which in turn is fed power from the ignition switch.
Anyway, the two movable contacts (the poles) are jumpered together, making the
switch act as a "shorting bar" in each of the "throw" positions.
From the schematic, I can't tell why the Brown lead needs to be grounded in the
Off position. It would have been clearer if there was some electrical detail
shown within the symbol for the wiper motor.
BTW, the schematic creates some confusion, with two separate switches labeled
"Switch 29." The left Switch 29 is clearly not the "Reverse Lamp Switch", but is
properly the "Windshield Wiper Control Switch." To the right of Switch 27 is the
correct Reverse Lamp Switch.
El Cajon, CA USA
Ed and Marc,
It turns out that my wiper switch explanation may not apply to your
car. My cars are late cars and at least the one I'm most familiar
with is not wired the way it shows in the schematic. The switch in
the schematic is quite unusual but could be reproduced by a double a
double pole, double throw (DPDT) switch with the center contacts tied
together. I've noticed several things in the schematics for these
cars are incorrect. The fact that the wiper switch is labeled as the
reverse lamp switch in the large schematic is only one of several
errors that I encountered in that schematic.
Ed,
What Amphicar was doing with the wiring shown in the schematic was to
ground the motor when the internal switch hit the park position.
This grounding acts like a brake to the motor to achieve a quicker
stop action. I don't know how many cars were wired with this
configuration. Like many things with these cars, sometimes you just
have to figure out what you have and how to handle it.
> From: John Friese
> Marc,
battery
this
to
is
to
or
motor
directly
continue
the
a "single
able
make
> John Friese
> 67 White
> 67 Red
> John:
shape that I didn't save it. However, when I look at the Amphi
schematic (the big plastic laminated one), I see that Switch 29 is
actually a Double Pole Single Throw (DPST) switch. In the Wipers OFF
position, the Brown wire from the wiper motor is grounded. When the
switch is activated, the Brown wire is not connected to anything
switch.
making the switch act as a "shorting bar" in each of the "throw"
positions.
grounded in the Off position. It would have been clearer if there was
some electrical detail shown within the symbol for the wiper motor.
switches labeled "Switch 29." The left Switch 29 is clearly not
the "Reverse Lamp Switch", but is properly the "Windshield Wiper
Control Switch." To the right of Switch 27 is the correct Reverse
Lamp Switch.
> Ed
> El Cajon, CA USA
> 67 Rust Guppy
mstrug@juno.com
John,Ed : I found a couple new switches on ebay. Seems the 1957- 62 bug used
them. They are slightly different; trim plate threads need a die run over them
to 5/16ths and have male spade terminals. Thanks for all the info! Still
haven't gotten to the horn, I think the contacts at the steering wheel are the
problem. Marc.
