Tom,
I just spoke to the wiperman (Fickens) and he apologizes as lately a few things have fell through the cracks as he stated. This is a busy time of year for him and he is a one man operation, plus he attends a few shows to vend.
He does stock these and said that a call is better than an email for him. Here is the article that ran in the newsletter way back when. Note: I am out of the adaptors:
Finally a reproduction wiper arm and blade combination that is readily available, looks presentable and actually works. As we all know locating NOS or good used wipers is becoming impossible to find yet affordable. I have been experimenting and using for over 3 years reproduction replacements that have been trouble free. For a little under $100 and a little polishing you can have two (2) new set ups.
Call Rob from Ficken Wiper Service (NY) at 631-587-3332 (
WiperMan.COM - Wipers, Wipers, Wipers) and ask for two (2) wrist action type passenger wiper arms for a 1948 Mercury / Ford that fit a 20-11 wiper blade of which you will also need two (2). Both the arm and blade are stainless steel with the arms already factory polished to chrome like finish. The blades are dull stainless (gray/silver) and will need taken apart (easy) to be polished to match the arms. I used Eastwood’s white rouge compound and did a pass with a Dremel 414, 429 and a 423E polishing wheel respectively, though other materials and wheels should work. Each blade took approximately a little over an hour to polish and reassemble.
The only part I have not found (as of yet) that is required is the adaptor that fits onto the existing Amphi wiper linkage shaft. This allows the connection of the new style arms. The adaptor has two (2) allen set screws that lock the new arm(s) onto the shaft. These adaptors can typically be found at antique automotive swap meets however you will need to drill them out to 15/64 to fit the shaft. Recommend filing any burrs off the existing shafts and polishing with a small wire wheel which Dremel also has. I do have some of these adaptors and a box of the special set screws.
After installing the adaptor to the shaft you may need to adjust / move the new arms several times to get them in the perfect park position on the windshield. When doing these adjustments use a spray bottle of water for accurate results, do not operate wipers on the windshield dry! Imagine being able to use your wipers knowing that they actually work and blade refills are available. Happy wiping!
