Windshield Wiper Motor Removal
I'm not sure I really want to remove my windshield wiper motor, but.....
Do the ball & socket joints on the linkage come apart. or are you supposed to
unscrew the link from the ball socket assembly, just leaving the ball & socket
together?
And then, how do you get at the bolt heads behind that darn bracket? Is a small
socket better than trying an open-end or box wrench? I suffer from big fingers,
and this looks like a tough job. OTOH, the rubber mounting washers are likely as
bad as all the rest of my gaskets and seals. So.......
Thanks!
supposed to unscrew the link from the ball socket assembly, just
leaving the ball & socket together?
They just "POP" apart. They may be reluctant to seperate, so use a
large flat screwdriver to coax them apart. Remember how they go back
together!
bracket? Is a small socket better than trying an open-end or box
wrench? I suffer from big fingers, and this looks like a tough job.
OTOH, the rubber mounting washers are likely as bad as all the rest
This is where patience (or a child) come in handy! I morph
into "Super wrench" Two fingers grow 2" longer and add another
universal knuckle at the 1st joint. ;) Actually, I used a small gear
wrench to get at them. VERY frustrating getting them out, worse going
back in. ;)
D windshield wiper motor bench test General Amphicar Discussion 3
T Looking for a Windshield Wiper Arm General Amphicar Discussion 8
G PS windshield wiper & stuff General Amphicar Discussion 0
Akamphi Windshield and door handle instal General Amphicar Discussion 1
laserfixr Windshield Wipers Stuck General Amphicar Discussion 5
tpls63 Windshield Wipers General Amphicar Discussion 7
G Windshield wipers and Stuff General Amphicar Discussion 2
G windshield washer pump General Amphicar Discussion 10
A Windshield / top / trunk boards wanted General Amphicar Discussion 0
B Amphi windshield General Amphicar Discussion 3
S windshield/SEEPs General Amphicar Discussion 1
D Lake Geneva, windshield rubber General Amphicar Discussion 0
I Windshield Rubber - a little advice General Amphicar Discussion 0
K windshield rubber General Amphicar Discussion 14
C Windshield gaskets... General Amphicar Discussion 0
B Windshield Update General Amphicar Discussion 3
P Windshield Totals General Amphicar Discussion 6
D windshield glass General Amphicar Discussion 4
B Amphi Windshield Smashed! General Amphicar Discussion 1
J Used Windshield needed General Amphicar Discussion 1
RalphF Repaired My Wiper Motor General Amphicar Discussion 4
Cameron in UK NOS Original Amphicar wiper blades available. General Amphicar Discussion 5
S Wiper Motor General Amphicar Discussion 3
A Wiper Blades On Ebay General Amphicar Discussion 0
C Wiper/Marine light dash switch placement ques. General Amphicar Discussion 1
Tom Laferriere Help with Wiper Blades and/or Arms General Amphicar Discussion 27
J Wiper blades and Floor mat kits General Amphicar Discussion 4
B Wiper Problem Solved General Amphicar Discussion 4
B Wiper Help General Amphicar Discussion 3
A WTB - Wiper arm General Amphicar Discussion 2
A Wiper Switch General Amphicar Discussion 6
L Inside the Wiper Motor: Contacts General Amphicar Discussion 1
L Wiper Motor Grease Question General Amphicar Discussion 1
R Wiper modification General Amphicar Discussion 0
T wiper motor General Amphicar Discussion 1
A Wiper motor question General Amphicar Discussion 1
J Damage Around Wiper Pivots General Amphicar Discussion 1
mike_israel Blackstone Labs Motor Oil Report General Amphicar Discussion 0
Jon March do new motor & tranny mounts affect motor height/fan shroud alignment? General Amphicar Discussion 11
Jon March is there a thread on steps to remove motor? - unsure how to unbolt, bolt locations, etc... General Amphicar Discussion 0
SNOWBIRD Motor Pull ? General Amphicar Discussion 1
sdreich Starter Motor Installation: A Two-person Job? General Amphicar Discussion 1
A Motor Oil For Flat Tappet Engines General Amphicar Discussion 4
S Blower Housing Motor & Mount General Amphicar Discussion 0
B Best Motor Oil for Amphicar General Amphicar Discussion 6
A Amphicar at Lowes Motor Speedway General Amphicar Discussion 0
G Motor out! General Amphicar Discussion 3
J MOTOR PARTS QUESTION - POSTED FOR ROB VONDRACEK General Amphicar Discussion 0
R 1296 motor General Amphicar Discussion 0
R 1147 motor General Amphicar Discussion 0
