Window Seal Track needed.
Arnold Hite
I am short two of the six aluminum tracks needed along the
convertable top. These are the tracks that hold the rubber seals that
press against the window glass when the windows are rolled up. The two
I am missing are the left and right rear. Part number is 12-45-23 L&R.
I have enough rubber seal left from my 1st car to replace one of the
seals, but I'll need about 2 ft more to do the second one. I'll be at
Celina if anyone has these parts for sale or trade.
Arnold Hite
Johns Island, SC
Jon March window adhesive General Amphicar Discussion 2
Akamphi Window felt/fuzzy instal General Amphicar Discussion 4
dutchamphi Window crank regulator gear General Amphicar Discussion 8
T Window Fuzzies Installation Question? General Amphicar Discussion 1
Amphipoda Back window mystery General Amphicar Discussion 3
T Vent Window Glass Installation General Amphicar Discussion 5
P Window Glass Removal General Amphicar Discussion 2
S gap between top and rear window General Amphicar Discussion 0
S Window Fuzzies General Amphicar Discussion 19
S triumph window fuzzies.........HELP General Amphicar Discussion 2
R Looking for rear window frame General Amphicar Discussion 0
K window fuzzy strips General Amphicar Discussion 0
R Window anti-rattle fuzzies General Amphicar Discussion 1
L Wanted: Chrome window frames General Amphicar Discussion 0
K Car show window sticker General Amphicar Discussion 2
L Window Guide Clips General Amphicar Discussion 0
P Window Regulator General Amphicar Discussion 3
B Water/land tranny seal Restorations in progress 15
B door seal test Restorations in progress 1
R hood seal on the body General Amphicar Discussion 1
Jon March Seal types - good info General Amphicar Discussion 0
Jon March when driveshaft seal-areas corrode General Amphicar Discussion 18
Jon March Seal popped out of hub!? General Amphicar Discussion 4
T Door Seal Question? General Amphicar Discussion 5
T Propeller Shaft Seal Installation General Amphicar Discussion 22
G Double Lip Oil Seal General Amphicar Discussion 1
D Trans seal General Amphicar Discussion 1
G door seal update General Amphicar Discussion 5
W seal replacement General Amphicar Discussion 1
B gas shut off seal disk General Amphicar Discussion 4
E Front Wheel Grease Seal General Amphicar Discussion 0
R Cable cover and cheep tailpipe pipe seal General Amphicar Discussion 0
G Seal between water and land trans General Amphicar Discussion 7
A Front wheel bearing seal General Amphicar Discussion 2
M New door area seam seal mouldings from Hugh. How to install?? General Amphicar Discussion 4
B rear axel seal replacement General Amphicar Discussion 0
B transmission axel seal replacement General Amphicar Discussion 1
T Double lip seal General Amphicar Discussion 5
J Rear Wheel Bearing Seal Orientation General Amphicar Discussion 1
T seal puller/prop removal General Amphicar Discussion 0
D Exhaust Seal General Amphicar Discussion 0
M Transmission Oil Seal General Amphicar Discussion 0
