Wheel Rims
I finally got around to demounting my old Vredestein tires and sending them off
to their unjust rewards. So now I'm cleaning the rims, and I'm getting a close
look at the rim markings.
All four rims are stamped with a "1371" and the size "4 1/2 -13". In addition,
there looks like a date code also stamped on each rim; my rims read 8/61, 8/61,
2/62 and 5/63. Kinda odd to date stamp the rims, but that's what I think these
codes must be. It's also odd that the size is stamped on the wheel in
non-metric. And what's the "1371" mean?
Finally, there's a manufacturer's logo on each wheel. As best I can see, the
logo is spelling out a name, something like:
Lem - - - -
The "L" is in a large script style, and the letter continues as a swooping arc
under the following letters. If I squint real hard, I might guess I'm seeing
something like Lemrotz or Lemnetz.
Anyone know what this manufacturer is/was?
E Amphi Wheel Rims General Amphicar Discussion 0
Ken Chambers Wheel bearing grease General Amphicar Discussion 15
Akamphi Wheel cylinder bleed screw General Amphicar Discussion 3
chapron67 Refinishing steering wheel General Amphicar Discussion 1
chapron67 Steering wheel General Amphicar Discussion 1
jfriese Smaller Steering Wheel General Amphicar Discussion 4
Midwest Amphicar New Amphi wheel houses shop "play time" General Amphicar Discussion 9
S Steering - Wheel Play - Normal? General Amphicar Discussion 4
D what is a "nardi" steering wheel and "proper mermaids" ??? General Amphicar Discussion 1
A Wheel Rim Rust General Amphicar Discussion 1
K SV: Looking for wheel(s) General Amphicar Discussion 0
K Looking for wheel(s) General Amphicar Discussion 1
T Rear Wheel Cylinders General Amphicar Discussion 0
J Amphicar Wheel Drawing General Amphicar Discussion 0
L Rear Wheel Bearing Play General Amphicar Discussion 0
W wheel bearing General Amphicar Discussion 3
G wheel kits General Amphicar Discussion 1
J Wheel Cylinder Rebuild Kits General Amphicar Discussion 6
B Fwd: Poorly Rebuilt Wheel Cylinders General Amphicar Discussion 1
D wheel cylinders winter sucks General Amphicar Discussion 1
M Poorly Rebuilt Wheel Cylinders General Amphicar Discussion 6
M Wheel Cylinder Rebuilding General Amphicar Discussion 2
R Play in wheel hub General Amphicar Discussion 3
