Wheel Covers
Hello,
I'm looking for a set of those, pebble grain, over the wheel well
rubber mats. I can repair cracks and am pretty good at cleaning up
the old glue and oxidized surfaces. If you've got a pair, contact me
off line.
jfriese@mindspring.com
Mark Richardson Steering Wheel Restoration Restorations in progress 5
Ken Chambers Wheel bearing grease General Amphicar Discussion 15
Akamphi Wheel cylinder bleed screw General Amphicar Discussion 3
chapron67 Refinishing steering wheel General Amphicar Discussion 1
chapron67 Steering wheel General Amphicar Discussion 1
jfriese Smaller Steering Wheel General Amphicar Discussion 4
Midwest Amphicar New Amphi wheel houses shop "play time" General Amphicar Discussion 9
S Steering - Wheel Play - Normal? General Amphicar Discussion 4
D what is a "nardi" steering wheel and "proper mermaids" ??? General Amphicar Discussion 1
A Wheel Rim Rust General Amphicar Discussion 1
K SV: Looking for wheel(s) General Amphicar Discussion 0
K Looking for wheel(s) General Amphicar Discussion 1
T Rear Wheel Cylinders General Amphicar Discussion 0
J Amphicar Wheel Drawing General Amphicar Discussion 0
L Rear Wheel Bearing Play General Amphicar Discussion 0
W wheel bearing General Amphicar Discussion 3
G wheel kits General Amphicar Discussion 1
J Wheel Cylinder Rebuild Kits General Amphicar Discussion 6
B Fwd: Poorly Rebuilt Wheel Cylinders General Amphicar Discussion 1
D wheel cylinders winter sucks General Amphicar Discussion 1
M Poorly Rebuilt Wheel Cylinders General Amphicar Discussion 6
M Wheel Cylinder Rebuilding General Amphicar Discussion 2
R Play in wheel hub General Amphicar Discussion 3
