Wheel brake cylinders
arctic432003
Can anyone tell me an other parts number, or what brand the wheel
brake cylinders front and rear are? They are missing on my car and I
cant find a replacement.
Front: 6-23-09 + 6-23-09A + 6-23-10 + 6-23-10A
Rear: 6-23-29
Willy from Belgium
WB6WSN
Sent: Friday, June 18, 2004 12:42 AM
Subject: [amphicar-lovers] Wheel brake cylinders
Rear: 6-23-29
Willy from Belgium
The original brand was "Ate". Cylinders are quite scarce, and nobody has
verified a cross reference to anything contemporary.
I recently suggested that the modern Ate Part Number 03.3222-8401.3 wheel
cylinder MIGHT work on the rear wheels. These look pretty close to the original
Amphi cylinders. Take a look for yourself on page 24 of the Ate HB 5 Hydraulic
Brake Parts Catalog at:
<a href="http://www.conti-online.com/generator/www/com/de/ate/ate/themen/kataloge/printkataloge/printkatalog_hb5_de.html">http://www.conti-online.com/generator/www/com/de/ate/ate/themen/kataloge/printka\
taloge/printkatalog_hb5_de.html</a>
Ate also shows master cylinders which also look like a close match to Amphi's,
but I didn't follow up on that. Unfortunately, I could not find any reference to
Ate single-piston wheel cylinders, like the ones used on Amphi's front wheels.
Perhaps one of our members more fluent in German could try to explore the Ate
site a bit better, or possibly even call Ate to see if they have a reference in
their files to what parts DKW originally bought from them back in 1960.
M Brake / Wheel Cylinder Bleeder General Amphicar Discussion 0
Ken Chambers Wheel bearing grease General Amphicar Discussion 15
Akamphi Wheel cylinder bleed screw General Amphicar Discussion 3
chapron67 Refinishing steering wheel General Amphicar Discussion 1
chapron67 Steering wheel General Amphicar Discussion 1
jfriese Smaller Steering Wheel General Amphicar Discussion 4
Midwest Amphicar New Amphi wheel houses shop "play time" General Amphicar Discussion 9
S Steering - Wheel Play - Normal? General Amphicar Discussion 4
D what is a "nardi" steering wheel and "proper mermaids" ??? General Amphicar Discussion 1
A Wheel Rim Rust General Amphicar Discussion 1
K SV: Looking for wheel(s) General Amphicar Discussion 0
K Looking for wheel(s) General Amphicar Discussion 1
T Rear Wheel Cylinders General Amphicar Discussion 0
J Amphicar Wheel Drawing General Amphicar Discussion 0
L Rear Wheel Bearing Play General Amphicar Discussion 0
W wheel bearing General Amphicar Discussion 3
G wheel kits General Amphicar Discussion 1
J Wheel Cylinder Rebuild Kits General Amphicar Discussion 6
B Fwd: Poorly Rebuilt Wheel Cylinders General Amphicar Discussion 1
D wheel cylinders winter sucks General Amphicar Discussion 1
M Poorly Rebuilt Wheel Cylinders General Amphicar Discussion 6
M Wheel Cylinder Rebuilding General Amphicar Discussion 2
R Play in wheel hub General Amphicar Discussion 3
