Ken Chambers
I've been trying different wheel bearing grease over the years in an attempt to make my front wheel bearings last longer due to rusting. Seems a year or two is all I get out of the bearings before they get noisy from pitting of the rollers and races. I replace the inner grease seal and have the rubber cap over the stub axle but water invariably gets inside. After the boating season I pull the wheels and hubs to allow any water to evaporate but that would certainly be a pain to do throughout the year.
The standard Molybdenum disulfide grease doesn't do the trick. I think the Moly is there for lubricity purposes and has nothing to do with anti-rusting.
I've tried boat trailer grease with near disastrous results. I found that it dried out and nearly burned up a bearing.
I've recently tried an LPS product called Aqua Bearing grease, touted for all its good grease characteristics plus excellent corrosion resistance and good adhesion properties.
Still have noisy bearings after a year.
Has anybody found a grease that is truly effective in preventing rusting of the wheel bearings?
