What is this brake line part
okey0
image.png This is maybe a spring loaded washer that fits between the rubber and metal brake line on rear brakes. I can't find it on Gordon's, not sure of name or part number. Can't seem to find the ones I took off, though they were kind of mangled.
Not something i have a inventory of but will keep my eyes open for them, you can put car together and come back later to install,
K Brake Line Bleeding General Amphicar Discussion 0
A Brake hoses and My ugly divorce General Amphicar Discussion 2
W brake hose question General Amphicar Discussion 1
