What gear lube?
okey0
is this the amsoil product that people are using in the land and water trans?
http://www.amsoil.com/shop/by-produ...-transmission-and-transaxle-gear-lube-75w-90/
I came across this stuff at carquest, for $8 per GALLON, and wondered if it would work in our trans: http://www.carquest.com/webapp/wcs/...ld+by+each__10151_-1_10651_1901051_?acesApp=0
they also have this stuff, for $9 a QUART: http://www.carquest.com/webapp/wcs/...ld+by+each__10151_-1_10651_1423166_?acesApp=0
what the heck is the difference in the carquest products? I did a search of the forum, but most threads were years old and a LOT has changed in oils. I want to make sure I stick with a GL4.
I would not put $8 a gallon oil in my 5- 10,000.00 Transmition.
Stick with the good old 80-90 type gear oils not the new syntetic that play havic on our syncro's
and if your rebuilding your Amphicar take the trany apart and get rid of the 50 year old gunge $%^^)(*# that collects on the bottom that will NOT drain oput!
Gord,
When I had a tranny rebuilt recently I drilled the drain plugs and installed some strong magnets into the plugs to collect steel debris that can cause failures. Perhaps you might like to produce such items for sale.
Regards,
mschlem Non-synthetic gear lube General Amphicar Discussion 4
M Tranny Gear Lube Removal General Amphicar Discussion 5
J Pumping out the gear lube General Amphicar Discussion 1
M Amsoil Gear Lube General Amphicar Discussion 0
Jon March Taller gear possibility? General Amphicar Discussion 8
Jon March Water trans drive gear retainer clips: General Amphicar Discussion 7
dutchamphi Window crank regulator gear General Amphicar Discussion 8
dutchamphi Gear Oil General Amphicar Discussion 2
C Third Gear General Amphicar Discussion 4
R 3rd Gear Clunk General Amphicar Discussion 5
S Gear Shift Return Spring General Amphicar Discussion 5
L Transmission gear oil leakage General Amphicar Discussion 19
A Top Gear video General Amphicar Discussion 0
E Speedometer Gear Ratio General Amphicar Discussion 0
B 1st & 3rd gear failure General Amphicar Discussion 0
C Left in Gear General Amphicar Discussion 1
E Hypoid Gear Oil General Amphicar Discussion 2
A Gear Noise General Amphicar Discussion 2
C Gear Mesh Noise Reduction General Amphicar Discussion 7
M Tranny gear oil General Amphicar Discussion 4
D Lucas lube Joints BW2 General Amphicar Discussion 0
A Speedometer Cable Lube General Amphicar Discussion 0
A Lube charts General Amphicar Discussion 0
