weights & tranny
  • Thread starter Thread starter Betty Anne and/or David Field
With all this talk about removing engines and transmissions and me having
to remove my transmission soon, I am wondering what the engines and
transmission each weigh.
Also what is club concensus regarding removing the tranny? Take the tranny
out by itself (Option 1)or remove engine and tranny together (Option
2)? Send in your vote!
My inner universal joint flew apart last year and in the process broke a
piece of the flange off so I will have to get it built-up so I can reattach
the boot. Any suggestions re welded build-up vs. epoxy?
Cheers, Dave on Wolfe Island, Canada
010513 Sun, Yes Dave, (Option 2) pull the drive shafts (wheels & props),
remove rad, hoist engine & tranny, 426 lbs wet. <the engines and
transmission each weigh.> engine 307 lbs., tranny 104 lbs. I know it
doesn't add up! (Option 1) If you don't have a hoist, wedge the engine at
the break in place, get those four bolts, you're stuck with a sling (Two
straps/ropes, front and back) under the tanny and over both sides, two
handlers two handed, puts it on the floor with the front seat removed.
Carefull of your back, it's not a pretty lift. Chuck, Murtle '64 Ivory.
broke a
reattach
I also have a transmission with a piece missing from the boot flange.
Does anyone have any experience with welding or patching the
transmission case? I always heard that old VW cases were a magnesium
alloy - much trickier to weld. Does anyone know if the Amphicar
transmissions are magnesium or aluminum?
Ken Chambers, CA
'64 Amphicar
Re: Re: weights & tranny
<font FACE="arial,helvetica"><font SIZE="1">Ken,
I just got my transmission back today from the machine shop. I had a 10 inch
crack in the bell housing. The transmission out of my 1964 was Aluminum and
came back from the welder looking good. I thought about the epoxy but I was
afraid it might give a little under stress so I went with welding.
Dave
64 RED
</font>
Ken, I have a complete, but disassembled Amphicar transmission in the
garage, both water & land halves. It was disassembled by a previous owner,
all parts should be there. I'm moving soon. If you're willing to ship it
from Port Townsend,WA it's yours!
--Larry Solheim ('66 Amphi & '64 MetalBeast)
Sent: Sunday, May 13, 2001 10:30 PM
Subject: [amphicar-lovers] Re: weights & tranny
> broke a
> reattach
> Ken Chambers, CA
> '64 Amphicar
