Water Transmission Cover Replacement
  • Thread starter Larry & Nancy Solheim
  • Start date
M Water in the transmission General Amphicar Discussion 0
B Water/land tranny seal Restorations in progress 15
Jon March Insurance pricing - land & water: General Amphicar Discussion 3
Jon March Suddenly "revving up" when in water -Does your Amphi do this? General Amphicar Discussion 12
E First day on the water General Amphicar Discussion 3
Jon March Water trans drive gear retainer clips: General Amphicar Discussion 7
SNOWBIRD Another on hits the dust(I mean water) General Amphicar Discussion 1
M water drive switch General Amphicar Discussion 4
Midwest Amphicar From Gizmag.com Water release seat belts General Amphicar Discussion 0
rhysaccess Water not draining General Amphicar Discussion 6
Akamphi Depth / water speed gauge in clock hole General Amphicar Discussion 1
Ed Price Update On Celina Water Problems General Amphicar Discussion 3
T Water pump General Amphicar Discussion 4
T Henry Ford and his Snow Tractor - wonder how it would do on the water? General Amphicar Discussion 2
B Water Car? General Amphicar Discussion 1
C Angle water shift is mounted? General Amphicar Discussion 2
kdroy Amphicar tranny land/water tear apart. General Amphicar Discussion 0
sdreich Water Pump Slot for Grease? General Amphicar Discussion 4
D Water throttle Happy VD General Amphicar Discussion 1
B Water Injection, Anyone? General Amphicar Discussion 5
D Salt Water General Amphicar Discussion 0
E Amphicar in salt water General Amphicar Discussion 7
D Water pump boom General Amphicar Discussion 1
J Water Tranny Problem General Amphicar Discussion 1
A White Lake NC Water Festival General Amphicar Discussion 1
W Austin Swim-in (was: Back in the Water!) General Amphicar Discussion 0
L Back in the Water! General Amphicar Discussion 2
M Looking for a water pump. General Amphicar Discussion 2
F water door lock General Amphicar Discussion 0
B Water tranny bearings General Amphicar Discussion 0
B Maybe fellow water lovers can help General Amphicar Discussion 0
J Water Leakage General Amphicar Discussion 0
R brakes in the water General Amphicar Discussion 2
B Water Test #6 General Amphicar Discussion 1
A Standing Water Tips General Amphicar Discussion 0
W water in fram General Amphicar Discussion 3
W Corrosion In Sea Water General Amphicar Discussion 3
W Fresh Water Cooling General Amphicar Discussion 0
G water leaks General Amphicar Discussion 0
E WATER CAR ON MSN.COM General Amphicar Discussion 0
