BrianF
Today at 9:13 AM
Hi
Servicing and fixing everything on car. Fluid service check. Brakes check. Chrome headlight trim check. Doors repaired and painted check. Gas sender float repaired check. New wood floors and trunk pieces in progress. And lots of cleaning and painting along the way. Every three or 4 years I completely remove interior and clean and inspect everything. I have lots of gear oil in the bilge and think it flows from the water tranny, through the land tranny, and out through the speedo connection. It's a chore to clean but worse than that is the smell. Its like the car has BO. I actually get a headache when the roof is up.
So I think its time to swap out the seal because when I check the water tranny level it is always low and needs topping off. I need a push to GO FOR IT!!! and change that seal. I have had the water tranny cover off before and swapped out the intermediate gears and needle bearings and was ok with all that. What I'm not cool with is setting up the shift shaft position when finishing up. It took me 8 hours and through trial and error I got it. Very confusing and frustrating. I am not sure what I did but think I just moved things around while changing parts and got the thing jammed up.
So Im looking for help, tips, encouragement, etc.
Thanks in advance.
Brian
Today at 9:13 AM
Hi
Thanks in advance.
Brian
