Water in my transmixer
  • Thread starter tommyintpa@aol.com
  • Start date
tommyintpa@aol.com
Hi again, So after swimming a lot the other day I had a load of water in the
tranny. This is what I did to remove it. I drained the goop out of the tranny,
very sad.
First I added a gallon of 90 weight and drove it around the block. Drained
out the goop it was the same goop as the first load, very sad.
Second I added a gallon of 90 weight and drove it around the block. Drained
out the goop/oil it was a little more like oil than before.
Third I added a gallon of 90 weight and drove it around the block. Drained
out the oil/goop it was even a little more like oil than before.
Forth I added a gallon of 90 weight and drove it around the block. Drained
out the oil/water it was a lot more like oil than before.
Fifth I added a gallon of 90 weight and drove it around the block. Drained
out the oil and it was like oil. Then filled it with Amsoil.
FIVE transmission oil changes in a row.
I'm ready for my contortionist audition now.
At least in my world a good contortionist can always get work.
Tommy at the circus in Tampa
