Water in engine
kdroy
This past winter I stored my Amphi in an enclosed trailer in MN.
Much to my horror, the trailer roof leaked & I ended up with water in my car.
This leaked occured in the spring, not winter, so it didn't freeze.
Unfortunately, I left the bilge plug in or it would have drained.
What I didn't realize right away is that water got into my engine.
I only had it running for a few minutes, but that was enough to mix up the oil/water into
a white slimy mess.
I've changed oil 4 times so far, (once with a a quart of kerosone) & ran it for a couple mintues. When I drain the oil, it still looks like chocolate milk.
Any ideas of how the clean this mess without tearing the engine apart?
Maybe if I change oil a dozen or so times, it'll clean itself.
Ken(KD) Roy
goobcarla
Ken - A number of years ago I sank one of my cars. It was close to shore, and once I retrieved it and dried things out, I changed the oil several times and drove the car back and forth to work everyday, about six miles roundtrip, I changed the oil every Saturday all summer and added a bit of Marvel Mystery Oil each time and never had a problem. I have since changed my ways and try not to sink them anymore!
Gary.
Midwest Amphicar
Disconnect oil cooler and blow out with air. I think I would use synthetic oil and run it. You could go further and pull out lifters, each one is a mini bucket holding goo. Pull off oil cooler attachment it has a pocket too. But you will never get moisture out if it never makes it up to operating temps. Later Dave
I have a large stock of used Oil, From Boats(low hours , changed every year so not so bad)
I use it over and over till all is black then go with new oil
As Dave said blowing out oil cooler will speed it up.
kdroy
I'm on my 9th oil change & the oil now loooks good.
I did the 1st 4 oil changes with used (filtered clean) oil & a quart of kerosene.
After the 3rd, I took the valve cover off & took an air hose & blew the oil out of the lifters.
I then stuck the air hose (with a 3ft 1/4" copper tube at the end)
into the oil pan & blew out a lot of sludge sitting on the bottom of the oil pan.
After each change, I let the engine run for about 5 minutes.
I did the next 4 with cheap new oil & a pint of sea foam.
In between these changes, I let the engine run longer to get it hot.
The 8th change came out looking good, so I put in the good stuff for the 9th.
I finally took the car for a swim & had no leaks!!!
I'm lucky this didn't happen last fall cuz it would've froze during the winter & destroyed my car.
Never again will I store the car with the bilge plug in!!
Ken (KD) Roy
B Water/land tranny seal Restorations in progress 15
Jon March Insurance pricing - land & water: General Amphicar Discussion 3
Jon March Suddenly "revving up" when in water -Does your Amphi do this? General Amphicar Discussion 12
E First day on the water General Amphicar Discussion 3
Jon March Water trans drive gear retainer clips: General Amphicar Discussion 7
SNOWBIRD Another on hits the dust(I mean water) General Amphicar Discussion 1
M water drive switch General Amphicar Discussion 4
Midwest Amphicar From Gizmag.com Water release seat belts General Amphicar Discussion 0
rhysaccess Water not draining General Amphicar Discussion 6
Akamphi Depth / water speed gauge in clock hole General Amphicar Discussion 1
Ed Price Update On Celina Water Problems General Amphicar Discussion 3
T Water pump General Amphicar Discussion 4
T Henry Ford and his Snow Tractor - wonder how it would do on the water? General Amphicar Discussion 2
B Water Car? General Amphicar Discussion 1
C Angle water shift is mounted? General Amphicar Discussion 2
kdroy Amphicar tranny land/water tear apart. General Amphicar Discussion 0
sdreich Water Pump Slot for Grease? General Amphicar Discussion 4
D Water throttle Happy VD General Amphicar Discussion 1
B Water Injection, Anyone? General Amphicar Discussion 5
D Salt Water General Amphicar Discussion 0
E Amphicar in salt water General Amphicar Discussion 7
D Water pump boom General Amphicar Discussion 1
J Water Tranny Problem General Amphicar Discussion 1
A White Lake NC Water Festival General Amphicar Discussion 1
W Austin Swim-in (was: Back in the Water!) General Amphicar Discussion 0
L Back in the Water! General Amphicar Discussion 2
M Looking for a water pump. General Amphicar Discussion 2
F water door lock General Amphicar Discussion 0
B Water tranny bearings General Amphicar Discussion 0
B Maybe fellow water lovers can help General Amphicar Discussion 0
J Water Leakage General Amphicar Discussion 0
R brakes in the water General Amphicar Discussion 2
B Water Test #6 General Amphicar Discussion 1
A Standing Water Tips General Amphicar Discussion 0
W water in fram General Amphicar Discussion 3
W Corrosion In Sea Water General Amphicar Discussion 3
W Fresh Water Cooling General Amphicar Discussion 0
G water leaks General Amphicar Discussion 0
E WATER CAR ON MSN.COM General Amphicar Discussion 0
T Water in my transmixer General Amphicar Discussion 0
