Video of correct method for top opening & closing
Jon March
could someone make and post an iphone video of how-to?
Reading the threads has me scared to attempt touching my top (that came in the up position when i bought it )@&^#
(and theres a gap between the silver pins above the windshield where it seems it should be better seated
....so im not sure if that means its improperly fitted and wont go back up if i release it?)
okey0
take a pic of the inside view showing the latches. to me that looks like the latches aren't completely locked in place. are you able to press the top down flush by hand?
Jon March
Thanks! - i just took a closer look - and the clamps are fully engaged inside - with a tight fit of the gasket.
on closer inspection - i see that (unlike the other corner that is fine) the front passenger-corner of the droptop frame is hitting the upper corner of the windshield area before the rest of the assembly is seated flush -
altho the clamp is fully engaged, the cestion in front of the passenger isnt seating nor is it able to be suched down
the topframe must be bent in some way, causing that corner to hit early -
maybe with a gear puller i can gently re-shape / bend out of that corner so it seats better...
mike_israel Old VW Schwimmwagen video General Amphicar Discussion 3
Jon March Ive never seen this video - but it may be the nicest one out there! General Amphicar Discussion 0
Jon March Nice video that shows land transmission drainplug General Amphicar Discussion 7
Jon March Video analysis - Eddie Dillard's epic splash/launching ! General Amphicar Discussion 6
F amphi in a video General Amphicar Discussion 6
JoeS An Amphicar in a Brad Paisley Video General Amphicar Discussion 0
B Amphi in Brad Paisley video General Amphicar Discussion 0
LSolheim Midsommer Amphicar Video General Amphicar Discussion 2
Ed Howard Another Amphicar video on You Tube General Amphicar Discussion 7
BuckeyeFloater The WaterCar (Not the Camaro) YouTube Video General Amphicar Discussion 2
LSolheim MORE Amphicar Video General Amphicar Discussion 3
G New Amphicar Video Clip / 4 Sail General Amphicar Discussion 1
D do it yourself video General Amphicar Discussion 2
R Amphi Trany Rebuild Seminar - How to Video? General Amphicar Discussion 1
A Top Gear video General Amphicar Discussion 0
T Video of my 1962 Amphicar for Sale General Amphicar Discussion 1
A Cool video General Amphicar Discussion 0
K Video Footage of Celina General Amphicar Discussion 1
E Swim With Dave Video General Amphicar Discussion 0
D video suffering General Amphicar Discussion 0
C Celina video General Amphicar Discussion 2
D Video Inspiration General Amphicar Discussion 0
K 2003 video General Amphicar Discussion 0
D Yahooo !!!!!!!!!!! Video has arrived General Amphicar Discussion 4
A New video file General Amphicar Discussion 0
D Later Celina Arrivals- Club Video General Amphicar Discussion 0
A alan jackson video General Amphicar Discussion 2
D Swim in 4th annual, Video tapes General Amphicar Discussion 0
A Who missed a video? General Amphicar Discussion 0
C Video Online General Amphicar Discussion 0
P Junk Yard Wars Video General Amphicar Discussion 1
B European Standard (PAL) Video Cassette Player General Amphicar Discussion 2
S My Classic Car Video General Amphicar Discussion 0
J Video Tapes and recovered data General Amphicar Discussion 0
D A must buy video General Amphicar Discussion 0
R Amphicar video General Amphicar Discussion 1
A Video of the Mass. 4 car mini-meet General Amphicar Discussion 0
Jon March correct rim color? General Amphicar Discussion 10
Stekiefa What is the correct connection of the ventilation / heating? General Amphicar Discussion 4
G New speedometer w/ correct miles General Amphicar Discussion 1
A New CORRECT or re-built shocks could be available General Amphicar Discussion 1
A Have a few of the correct fuel pumps General Amphicar Discussion 0
T John was correct Nikita has a hot coil General Amphicar Discussion 2
M Which is correct? General Amphicar Discussion 0
C Politically Correct??? General Amphicar Discussion 1
D Correct dwell angle?? General Amphicar Discussion 0
J Correct colors... General Amphicar Discussion 0
R Correct URL for Milwaukee Amphi General Amphicar Discussion 0
