Underside hull paint and engine compartment paint
Craig
Is there a proper color code for under side hull paint or just plain
jane Simi Gloss black?
What about the thick coating in and around the engine compartment. Is
it worth while to try to duplicate that or just use the sound deading
kit from Gord?
Craig,
Semi Gloss black on the underside is just fine. On the inside I
prefer to use a commercial mastic coating like Dupont Corlar 25P.
It's like a thick paint that you can even roller on to give it a
thickness that resembles the original Amphicar interior coating. It
comes in colors and can be custom blended to make it whatever color
you want, though I found two off the shelf colors worked great for my
two cars. It doesn't require a primer and isn't UV sensitive. It was
one of the best tips I ever got on Amphicar restoration and it came
from Billy Syx of East Coast Amphicar. It's an epoxy, two part
material that comes in what they call a 1 gallon size but that's
actually 2 gallons since you mix it 50/50 with it's hardener material.
Two gallons is just right for coating the whole back end up to the
fins, the middle section up to the top and the front section up to the
cross member under the spare tire. The inside of the front trunk area
is best painted with a marine top side paint mixed with as much
flattening agent as it will take. The flatter finish in the upper
trunk area hides minor sins.
> kit from Gord?
Is
deading
> kit from Gord?
Go with John F's advice on the mastic. The proper color for the bottom
is really a satin black which is slightly less glossy than semi-gloss.
There is a truck bed undercoating that works very well for this. The
can has a blue and white label and I have found it at Auto-Zone,
Checker and Wal-Mart for about $7 a can. 3 or 4 will do the underside
and it helps seal and protect the bottom. It has a very slight texture
to it.
John Bevins
Alaskan Amphi
How about a spray on bed liner product? Something like the Line-x or
Rhino liner brand for the underside. I'd guess it could be done in a
Satin black and with out the non skid stuff they use in pick up bed
liners. That would give the under side a bit more durability for the
occasional underwater obstacle.
Craig in Alaska
L
Larry & Nancy Solheim
Re: Re: Underside hull paint and engine compartment paint
We did that on MetalBeast (a '64 I restored), Craig. It turned out quite nicely. --Larry
Alaskan Amphi <taylorcm@alyeska-pipeline.com> wrote: <blockquote class="replbq" style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid"> <div id="ygrp-text"> How about a spray on bed liner product? Something like the Line-x or
Craig in
Alaska
</blockquote>
<hr size="1">Want to be your own boss? Learn how on Yahoo! Small Business.
Mike Israel
<table><div style="font-family:times new roman, new york, times, serif;font-size:12pt"><div style="FONT-SIZE: 12pt; FONT-FAMILY: times new roman, new york, times, serif">The advantage to good old fashioned paint is that you will not have to worry about water being trapped underneath and causing considerable unseen damage. Over time, this was the problem experienced with undercoating such as Ziebart. It has also been seen with Por-15. Sure, Ziebart seemed like a great idea at the time but the cure turned out worse than the disease. If you paint starts flaking or bubbling the area is likely to be easily spotted and can be just as easily repaired. The other consideration with any coating is "what will it take to remove it". Several restorers, including some in the Amphi community, have stated that they will add $5,000 to the cost of restoring any car that has
been undercoated. If whatever you put on there can not be easily removed with bead blasting or sanding, stay away from it.
<span style="COLOR: white"><span style="COLOR: white"></span></span>
--- In amphicar-lovers@yahoogroups.com, Mike Israel
experienced with undercoating such as Ziebart... <SNIP>
There are several types of coatings available. The one I use takes
no more effort to remove then paint does and it will adhere as paint
does as long as the surface is prepped properly. That is the key,
careful preparation. Just like quality paint, prepare the surface
properly and it will last for decades.
Rhino lining and the like are not good choices. They are typically
put on very thick and that adds a lot of weight (100+ lbs). The
product I use is only about twice the thickness of paint and had
only a slight texture. The bottom of my white driver over almost 5
years, has 250+ hours in the water and 5500 miles on land. There are
no problem areas anywhere.
John Bevins
Midwest Amphicar Ahhh go to hull Restorations in progress 7
Midwest Amphicar proper or improper way to check hull General Amphicar Discussion 5
CapnJohn Free hull! General Amphicar Discussion 2
A hull protection coatings??---other than paint on the outside?? General Amphicar Discussion 5
A Space between prop and hull General Amphicar Discussion 2
R gauge of the hull General Amphicar Discussion 0
E Hull Drain Pipe (Leaks) General Amphicar Discussion 1
V hull paint General Amphicar Discussion 4
Midwest Amphicar The Smell of Victory or paint or ............ General Amphicar Discussion 3
Ed Price Fjord Green Paint Code General Amphicar Discussion 3
W Fjord Green Paint General Amphicar Discussion 0
H paint code General Amphicar Discussion 8
B Bow Light Paint General Amphicar Discussion 11
Akamphi Finally in paint! General Amphicar Discussion 8
P Paint General Amphicar Discussion 18
Akamphi Paint codes General Amphicar Discussion 2
W Amphicar Paint Colors General Amphicar Discussion 6
W Paint General Amphicar Discussion 15
K Engine compartment paint. General Amphicar Discussion 2
L Propeller Paint and Cleaning General Amphicar Discussion 3
M ebay Paint chips General Amphicar Discussion 0
C Black under side paint General Amphicar Discussion 2
A Shrouds, glove boxes, paint, and new parts General Amphicar Discussion 1
J paint and towing an amphi and magnets General Amphicar Discussion 1
S Touch-Up Paint and Insurance questions... General Amphicar Discussion 9
S Steering wheel Paint... General Amphicar Discussion 1
M Paint Code General Amphicar Discussion 0
J paint for the valve cover General Amphicar Discussion 3
J Paint code for red amphi in ICI paint General Amphicar Discussion 0
J stripping the paint on an amphi General Amphicar Discussion 1
A Daily drivers and paint General Amphicar Discussion 0
S Color codes and paint suggestions and transport tie down tips General Amphicar Discussion 2
A New Topic: Paint Removal General Amphicar Discussion 0
E Paint Planning General Amphicar Discussion 0
A BODY PAINT PREPARATION General Amphicar Discussion 0
R Paint recommendations General Amphicar Discussion 1
M Underbody Paint General Amphicar Discussion 2
C Pictures of my paint job... General Amphicar Discussion 2
B Amphicar Paint Formulas Followup General Amphicar Discussion 0
M Paint Codes General Amphicar Discussion 1
M Fun and Paint General Amphicar Discussion 0
