U Joints
Canadian four amphs
A club member put me in touch with a U joint expert in Ohio,
we have been working on all 3 types 30 mm and 28 mm are no problem
but the 24 mm are a little more fun.there is one for a mazda thats 51mm inside, we need 57mm and he can have them made but min. order is 500
This still will need a mod to the yokes but a simple one, If anyone else has found a cure or is working on it I need to Know , as there probably isn't even 250 axles of this type out there needing replacement.
Gord
SNOWBIRD 24mm u joints General Amphicar Discussion 3
F U Joints General Amphicar Discussion 0
A Prop U Joints on EBay General Amphicar Discussion 0
C Prop driveshaft u-joints sloppy? General Amphicar Discussion 6
W Drive Shaft U joints General Amphicar Discussion 2
T Axle u-joints General Amphicar Discussion 3
G U Joints! General Amphicar Discussion 3
G U Joints. General Amphicar Discussion 0
D 30mm x 81.8 u-joints General Amphicar Discussion 0
B Oil Change Joints General Amphicar Discussion 0
B SV: SV: SV: Propeller Shaft U-Joints General Amphicar Discussion 0
B SV: SV: Propeller Shaft U-Joints General Amphicar Discussion 1
B SV: Propeller Shaft U-Joints General Amphicar Discussion 3
A Propeller Shaft U Joints General Amphicar Discussion 1
S Propeller Shaft U-Joints General Amphicar Discussion 0
E Inspecting Prop Shaft U-joints General Amphicar Discussion 0
D Lucas lube Joints BW2 General Amphicar Discussion 0
T u-joints NAPA part # 812 & # 317 General Amphicar Discussion 0
R Stubborn ball joints General Amphicar Discussion 1
D u joints General Amphicar Discussion 1
M Al Heath concerning rear alxe u-joints General Amphicar Discussion 0
B U-joints, etc. General Amphicar Discussion 0
C U-Joints General Amphicar Discussion 1
A prop shaft u-joints General Amphicar Discussion 0
