Triumph Engines 1147
  • Thread starter Michael Echemann
  • Start date
Michael Echemann
Today was a great day in Chicago for Feb. Temps in the mid 50's so I
decided to do a bit of work in the garage. This is something I haven't
really done in about 8 months. I decided to finally start up an Amphicar
which had not run in about 36 years. Last year I changed the fuel and water
lines etc. and had a bit of marvel mystery oil in the cylinders so I was
pretty much ready. After checking things and hooking up the fuel line I
blew out the cylinders, sanded down the points and installed the plugs.
After a few turns I connected the coil and gave it a try. After a few
tries I found no fuel was getting to the carb so I changed the pump and off
she went. It smoked for more than a few minutes after it came to life and
burned off the marvel then settled in as new. These 1147's are not
powerful but sure seem to be pretty bullet proof.
As I let the engine run to full warm status I noticed antifreeze leaking
down the inside wheel hump on the passenger side. It was coming from the
heater opening where air blows underneath the passenger leg area. (heater
is on the side of tank). Since I can feel or see the hose connections to
the heater and they are dry I'm assuming it's the heater core. Does anyone
have any other suggestions.
Thanks
L
Larry & Nancy Solheim
How does the heater valve look, Mike? It could be as
simple as a dry, cracked o-ring on the cylinder;
particularly as long as she has sat.
--Larry
> the mid 50's so I
> something I haven't
> try. After a few
> Thanks
> Mike
http://mail.yahoo.com
P Expert Article on Triumph (Amphicar) 4 cylinder engines General Amphicar Discussion 0
S US Vendors With Triumph Herlad Parts? General Amphicar Discussion 21
G 1500cc Triumph & cooling General Amphicar Discussion 55
S triumph window fuzzies.........HELP General Amphicar Discussion 2
R 1147 rebuilt Triumph Spitfire long-block General Amphicar Discussion 0
E Triumph Engine Numbering General Amphicar Discussion 1
R Triumph Thermostat? General Amphicar Discussion 0
E Triumph Engine Substitute General Amphicar Discussion 1
M eBay Motors item 596009781 (Ends Oct-07-01 115209 PDT ) - Triumph Spitfire Mks General Amphicar Discussion 1
T Triumph Sports Six Club international General Amphicar Discussion 0
A Motor Oil For Flat Tappet Engines General Amphicar Discussion 4
Midwest Amphicar Engines engines who needs an engine General Amphicar Discussion 4
D engines transmissions BW2 General Amphicar Discussion 1
G Engines and tranys General Amphicar Discussion 1
M building 1500cc Spitfire engines General Amphicar Discussion 0
R Worm Shop building 1500cc Spitfire engines General Amphicar Discussion 1
D engines and sons General Amphicar Discussion 1
M Engines&Clutches General Amphicar Discussion 3
amphicarian Spark Plug Choices for 1147 General Amphicar Discussion 4
amphicarian 1147 crank for sale? General Amphicar Discussion 1
C 1147 Oil pan w/ new oil pump General Amphicar Discussion 0
B 1147 cc engine advice needed General Amphicar Discussion 2
R 1147 motor General Amphicar Discussion 0
M 1147 Engine General Amphicar Discussion 2
