Triumph Engine Substitute
I suppose this is a subject with rather limited interest, but it could be
important to an extreme Amphi project.
I have always liked Chevy engines, and I recently found out that Chevy made an
L4 engine that was offered in Chevy II / Novas from about 1962 to 1970. Chances
are good that you could find one in a junkyard. I don't know about clearances or
mounts, but the idea somehow intrigues me.
No, I don't intend to swap my 1147 for a Chevy (I have enough work to do
already), but if I could have any engine I wanted, the Chevy would rank above
the 1147. Gee, as long as I'm dreaming, maybe the best choice would be a little
4 cylinder diesel (Volvo or Ford?).
P
paul.j.rasmussen@GM.com
Alot of the German club guys are using the Opel 1.2L and 1.4L engines from
the '70's and 80's (carb. models). Alot more reliable than the Triumph
motors.
Chev II motor might work but could be too heavy (although the 1200 Triumph
is pretty heavy itself).
PJR
E Triumph Engine Numbering General Amphicar Discussion 1
S US Vendors With Triumph Herlad Parts? General Amphicar Discussion 21
G 1500cc Triumph & cooling General Amphicar Discussion 55
S triumph window fuzzies.........HELP General Amphicar Discussion 2
M Triumph Engines 1147 General Amphicar Discussion 1
R 1147 rebuilt Triumph Spitfire long-block General Amphicar Discussion 0
R Triumph Thermostat? General Amphicar Discussion 0
M eBay Motors item 596009781 (Ends Oct-07-01 115209 PDT ) - Triumph Spitfire Mks General Amphicar Discussion 1
T Triumph Sports Six Club international General Amphicar Discussion 0
P Expert Article on Triumph (Amphicar) 4 cylinder engines General Amphicar Discussion 0
SNOWBIRD Engine surprise General Amphicar Discussion 1
D Engine Draft Tube General Amphicar Discussion 3
Jon March Proper engine break-in General Amphicar Discussion 4
mike_israel 2-ton engine hoist for $143 General Amphicar Discussion 0
Jon March Engine compartment - !@# manual scraping. stripping, degreasing, sanding, priming, painting General Amphicar Discussion 6
P cautionary tale (my engine upgrade experience) General Amphicar Discussion 14
okey0 Engine OUT....how to mount on stand now? General Amphicar Discussion 9
Akamphi Engine oil priming tool General Amphicar Discussion 3
Ken Chambers Entertaining engine rebuild General Amphicar Discussion 0
Akamphi Spit 1500 engine break in. General Amphicar Discussion 1
AHite Possible Engine Conversion General Amphicar Discussion 8
S Pulling an engine General Amphicar Discussion 7
A engine timing and dwell General Amphicar Discussion 3
Midwest Amphicar Engines engines who needs an engine General Amphicar Discussion 4
azpaul50 Engine Cover Luggage rack General Amphicar Discussion 6
Midwest Amphicar Engine cover holes or how I spent today General Amphicar Discussion 1
B Re: Engine cooling fan General Amphicar Discussion 0
B engine cooling fan General Amphicar Discussion 2
amphicarian Engine advice General Amphicar Discussion 19
DavidC Amphicar engine in Alabama General Amphicar Discussion 0
A engine milage and mechnical status General Amphicar Discussion 7
K Engine compartment paint. General Amphicar Discussion 2
W engine and transmision General Amphicar Discussion 4
C engine rebuild General Amphicar Discussion 1
C Underside hull paint and engine compartment paint General Amphicar Discussion 6
W engine manifold mystery General Amphicar Discussion 7
