Dave Derer
It sounds like the "special bearing" is bad or not shimmed properly.
Allowing the shaft to move back and forth. That changes the pinion depth
which causes howling. Maybe it is moving enough for gears to be grinding
on each other. Maybe you knocked spring off double lip seal when
installing. That little guy loves to travel and can make differential
bearings sing. If this is a recent Hugh rebuild call Hugh. A similiar
situation happened on another trans and Hugh stood behind it and was
willing to make right. Hey John maybe you have a bad rotor! Later Dave
the Wave
white 64 still upside down
red 67 still not red
red 66 still not red
red 64 still red
green 68 still not off trailer
blue 64 still no chrome
white 62 still frozen
yellow 61 less than before
black 66 lot less than before
red 67 still dead in barn
the Wave
red 64 still red
