I recall there being a thread last year about the best way to lower the rear
wheel to allow the axle to slip out of the transaxle carrier enough to allow the
transmission to be pulled from the Amphi. I looked at the file archives, but it
still seems to be unsettled as to which is the best way to do this job.
The Amphi manual says to remove the Oscillating Arm off of the Axle Shaft, using
a special puller tool. But some posters have worried about the strength
Oscillating Arm Hexagon Bolt, and even damaging the clamping end of the
Oscillating Arm.
An alternate method was proposed; to not loosen the Oscillating Arm / Axle
joint, but rather to remove the six bolts from the axle housing, allowing the
entire housing to move outward.
The alternate method sounds like more work, but damaging the oscillating arm is
certainly something to be avoided. To those who have been there and done that,
what's your opinion?
Oscillating Arm.
