Transmission rebuilt cost
wcapron2001
I would have to look back at the reciepts to give you an exact
figure. I performed the labor myself and parts (front pinion bearing,
mainshaft gearset bearing set, 2 gaskets and 4 seals) about $300.00.
A considerable savings over the cost of a rebuilt transmission
exchanged!
Bill
Rebecca Gilbert
Bill,
Thanks for the info. Hope it runs out great for you.
Bobby
>From: "wcapron2001" <wcarron@qwest.net>
>Reply-To: amphicar-lovers@yahoogroups.com
>Subject: [amphicar-lovers] Transmission rebuilt cost
>Date: Wed, 23 Jun 2004 15:36:29 -0000
>exchanged!
>Bill
Make the most of your family vacation with tips from the MSN Family Travel
Guide! http://dollar.msn.com
S Rebuilt transmission installed General Amphicar Discussion 2
John Howland Transmission fluid levels General Amphicar Discussion 4
C Noise from transmission or clutch General Amphicar Discussion 5
Jon March Nice video that shows land transmission drainplug General Amphicar Discussion 7
jfriese Transmission Dipstick General Amphicar Discussion 4
T Transmission Fun General Amphicar Discussion 0
B Transmission oil leak General Amphicar Discussion 4
B Transmission oil leak General Amphicar Discussion 7
Steve Transmission leaking oil General Amphicar Discussion 7
Midwest Amphicar Transmission Tech Session at Gators Amphicar March 21st + lunch General Amphicar Discussion 5
jfriese Looking for Transmission Tool General Amphicar Discussion 2
MAE Transmission for Sale General Amphicar Discussion 0
E Transmission fluid level General Amphicar Discussion 2
Midwest Amphicar Transmission for sale General Amphicar Discussion 10
C Rust free body with extra NOS transmission on Ebay General Amphicar Discussion 3
sdreich Amphi Transmission Removal General Amphicar Discussion 5
Midwest Amphicar Transmission tunnel boot opinion General Amphicar Discussion 3
B Transmission mystery solved General Amphicar Discussion 3
E Transmission Oil & Differential Oil General Amphicar Discussion 1
G Transmission Symetry General Amphicar Discussion 0
B transmission leak General Amphicar Discussion 2
L Transmission gear oil leakage General Amphicar Discussion 19
K Modified transmission mount bolts General Amphicar Discussion 0
G Transmission Rebuild General Amphicar Discussion 1
L Transmission oil seals General Amphicar Discussion 2
D Lake of the Ozarks transmission for sale General Amphicar Discussion 0
S Transmission Linkage pops out.... General Amphicar Discussion 5
W Transmission rebild General Amphicar Discussion 1
W Transmission bearings and gaskets General Amphicar Discussion 0
D reversing transmission General Amphicar Discussion 0
R new transmission for sale General Amphicar Discussion 0
E Transmission Input Shaft Radial Play General Amphicar Discussion 1
A Transmission Plug General Amphicar Discussion 2
E Transmission Removal General Amphicar Discussion 5
S Transmission Levels General Amphicar Discussion 2
S Transmission Dip Stick General Amphicar Discussion 1
R Is transmission venting necessary General Amphicar Discussion 4
D Transmission Bummer - Update General Amphicar Discussion 0
