Transmission oil seals
L
lah20car@aol.com
<font FACE="arial,helvetica"><font SIZE="2" PTSIZE="10" FAMILY="SANSSERIF" FACE="Arial" LANG="0">In a message dated 4/11/2006 6:52:18 AM Central Daylight Time, willy-linda@pandora.be writes:
<blockquote TYPE="CITE" style="BORDER-LEFT: #0000ff 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px">Do I need a special tool ?
</blockquote>
Aloha to Belgium--not that I know a lot about it but when I did mine I had the same problem and trying to work inside the car was a pain, lots of them, so what I did was make something like what a body shop would use, called a slide hammer, take a 1/2 rod about 4 feet long, heat and flatten one end, then heat it again about an inch back and bend it a little more than 90 degrees so that it will fit inside the seal, thread the other end just a bit, slide something like a heavy sleeve or piece of pipe, put a washer and nut on the end and you have a Cajun double lip seal remover--confused yet?? fotos if needed--Ken</font>
arctic432003
What is the easiest way to remove the double lip oil seals
(part 2-17-12) from the tranny via the outside ?
Willy from Belgium
arctic432003
> willy-linda@... writes:
mine I had
lots of them, so
called a slide
end, then heat
degrees so that
slide something
end and you
needed--Ken
If you can mail me a picture to willy-linda@pandora.be it would be
nice .
Is it possible to damage the inner lips from the tranny ?
Willy
