Transmission noise update
wick68355@aol.com
Congrata on the new trans. Does it shift to all gears smoothly? How about
down shifting? Let me know I think many would be interested.
Tim Wick
wcapron2001
Fellow amphibians,
I spent Friday afternoon changing the transmission. I did it by
removing the back seat in about 4 1/2 hours. The NOS transmission
from Gordons is as quiet as a mouse. In short, its as good as the old
one was bad. My wife and I drove it down to Olympia on Saturday,
about 70 miles, and swam it in Lake St Clair. This is a fairly small
lake very much suited for a Amphicar. My mother in law directed me
around from house to house to show it off to all of her friends. I
pointed out to her that her picture was being taken more that day
than it had been on the day she got married.
I ran into one problem that may explain the breaking of plastic
generator pullys. I had my generator rebilt shortly after buying the
car and it has sat on the shelf for 7 years. In that time the grease
had dried out leaving the rear bushing without lubrication. When the
rear bushing wears and the generator gets hot it will rub the
armature against the field magnets and cause excessive drag on, and
heat to the pully causing failure. The soultion is a new bushing and
a metal pully.
The best part of the Amphicar is the looks on peoples faces as you
drive in and out of the water. Were having lots of fun with it now.
Bill Capron
C Noise from transmission or clutch General Amphicar Discussion 5
W Transmission noise General Amphicar Discussion 6
John Howland Transmission fluid levels General Amphicar Discussion 4
Jon March Nice video that shows land transmission drainplug General Amphicar Discussion 7
jfriese Transmission Dipstick General Amphicar Discussion 4
T Transmission Fun General Amphicar Discussion 0
B Transmission oil leak General Amphicar Discussion 4
B Transmission oil leak General Amphicar Discussion 7
Steve Transmission leaking oil General Amphicar Discussion 7
Midwest Amphicar Transmission Tech Session at Gators Amphicar March 21st + lunch General Amphicar Discussion 5
jfriese Looking for Transmission Tool General Amphicar Discussion 2
MAE Transmission for Sale General Amphicar Discussion 0
E Transmission fluid level General Amphicar Discussion 2
Midwest Amphicar Transmission for sale General Amphicar Discussion 10
C Rust free body with extra NOS transmission on Ebay General Amphicar Discussion 3
sdreich Amphi Transmission Removal General Amphicar Discussion 5
Midwest Amphicar Transmission tunnel boot opinion General Amphicar Discussion 3
B Transmission mystery solved General Amphicar Discussion 3
E Transmission Oil & Differential Oil General Amphicar Discussion 1
G Transmission Symetry General Amphicar Discussion 0
B transmission leak General Amphicar Discussion 2
L Transmission gear oil leakage General Amphicar Discussion 19
K Modified transmission mount bolts General Amphicar Discussion 0
G Transmission Rebuild General Amphicar Discussion 1
L Transmission oil seals General Amphicar Discussion 2
D Lake of the Ozarks transmission for sale General Amphicar Discussion 0
S Transmission Linkage pops out.... General Amphicar Discussion 5
W Transmission rebuilt cost General Amphicar Discussion 1
W Transmission rebild General Amphicar Discussion 1
W Transmission bearings and gaskets General Amphicar Discussion 0
D reversing transmission General Amphicar Discussion 0
R new transmission for sale General Amphicar Discussion 0
S Rebuilt transmission installed General Amphicar Discussion 2
E Transmission Input Shaft Radial Play General Amphicar Discussion 1
A Transmission Plug General Amphicar Discussion 2
E Transmission Removal General Amphicar Discussion 5
S Transmission Levels General Amphicar Discussion 2
S Transmission Dip Stick General Amphicar Discussion 1
