Fw: Transmission mystery solved
<table><div style="font-family:times new roman, new york, times, serif;font-size:12pt"><div style="FONT-SIZE: 12pt; FONT-FAMILY: times new roman, new york, times, serif">FYI. From an old timer Amphi mechanic...
<div style="FONT-SIZE: 12pt; FONT-FAMILY: times new roman, new york, times, serif">----- Forwarded Message ----
Sent: Monday, October 15, 2007 5:36:04 PM
Subject: Re: Transmission mystery solved
<font face="Arial" size="2">Mike,</font>
<font face="Arial" size="2"> You don't know me. I have been following the amphi postings for the last several years. I am a physically tired - retired wrench. I worked on Amphis in the early 70's when people drove them everyday because they had too much invested to just let them sit and nobbody would buy them. Usually they were well rusted, looked like swiss cheese, and were greatly ignored. Rare was the wrench that would work on them. I however used to.</font>
<font face="Arial" size="2"> My none to great experience with tranny R&Rs technique would be thus:</font>
<font face="Arial" size="2"> pop both hub caps &loosen all lugs</font>
<font face="Arial" size="2"> jack & block rear of body as necessary</font>
<font face="Arial" size="2"> remove both rear wheel assy's</font>
<font face="Arial" size="2"></font><font face="Arial" size="2">Pull both trailing arm assy's & shafts as necessary</font>
<font face="Arial" size="2"> loosen both do-nut shaft tube to body seals at trans</font>
<font face="Arial" size="2"> * * * O P T I O N A L * * *</font>
<font face="Arial" size="2"> pullfront seat to provide legroom</font>
<font face="Arial" size="2"> throw down at least 2 inch thick padded mat by rear bulkhead to preserve knees from hard as steel ribbing on OEMfloormat</font>
<font face="Arial" size="2"> * * *N E C E S S A R Y * * *</font>
<font face="Arial" size="2"> undo shifter by trans</font>
<font face="Arial" size="2"> unhook clutch cable at release arm</font>
<font face="Arial" size="2"> unbolt both trans mounts</font>
<font face="Arial" size="2"> unhook back up light switch</font>
<font face="Arial" size="2"> (I think it is by the trans. Hey, I haven't done this since 1975 and a lot of water has gone under the bridge since then.)</font>
<font face="Arial" size="2"> unbolt all but 5 or 6 of the twelve hundred seventy four bolts that hold the trans to the 40 hp engine (hemi's took 6)</font>
<font face="Arial" size="2"> lift trans at least about 4 inches at the boat end and slide something under the engine pan to maintain the new tilt</font>
<font face="Arial" size="2"> I think the starter has to be pulled and maybe the battery disconnected (I remember it being an inward pull)</font>
<font face="Arial" size="2"> put some kind of block under the trans to support it while removing the last 5 or 6 bellhousing bolts</font>
<font face="Arial" size="2">undo the last b - bolts and pull the bugger back.</font>
<font face="Arial" size="2"> The purpose of tilting the engine is to make wrastling the trans easier by not being down at floor level. You can pull the rear decklid and block across the fins if you REALLY want, but that is to much like work. Just tip ita bit and go. I would use some kind of strange bolt to be2makeshift dowel pinslike onAmerican engines to facilitate bellhousing re-alignment. Remove after re-install if you want to be O.E.M. I remember it being difficult to realign. </font>
<font face="Arial" size="2"> This is the first time I have responded to postings. You can foreward it if you choose. I watch all the kafuffel over suspension etc. Such fun. Most of this I did so long ago. Some I remember. More later if you guys get stuck.</font>
<font face="Arial" size="2">Al</font>
<font face="Arial" size="2">Detroit-Deutsch</font>
<font face="Arial" size="2"> </font>
