Transmission fluid level
echassignet
Maybe it is in the manual(s), but I could not find it.
What is the best way to check the transmission fluid level on the land side? Thanks
Eric
67 white
Hello Eric,
The best way is to get an extended dip stick from Rob Von Dracek and check the level from the engine compartment when you end the day out on the water. If water has gotten into the land tranny it will show up as bubbles on the stick and you can quickly drain the tranny and refill it before rust ruins it. For the initial check of both the land and water tranny I would suggest you buy the regular length dip stick that John Capone sells on Ebay. It will establish the proper levels for both trannys during maintenance sessions.
John Howland Transmission fluid levels General Amphicar Discussion 4
C Noise from transmission or clutch General Amphicar Discussion 5
Jon March Nice video that shows land transmission drainplug General Amphicar Discussion 7
jfriese Transmission Dipstick General Amphicar Discussion 4
T Transmission Fun General Amphicar Discussion 0
B Transmission oil leak General Amphicar Discussion 4
B Transmission oil leak General Amphicar Discussion 7
Steve Transmission leaking oil General Amphicar Discussion 7
Midwest Amphicar Transmission Tech Session at Gators Amphicar March 21st + lunch General Amphicar Discussion 5
jfriese Looking for Transmission Tool General Amphicar Discussion 2
MAE Transmission for Sale General Amphicar Discussion 0
Midwest Amphicar Transmission for sale General Amphicar Discussion 10
C Rust free body with extra NOS transmission on Ebay General Amphicar Discussion 3
sdreich Amphi Transmission Removal General Amphicar Discussion 5
Midwest Amphicar Transmission tunnel boot opinion General Amphicar Discussion 3
B Transmission mystery solved General Amphicar Discussion 3
E Transmission Oil & Differential Oil General Amphicar Discussion 1
G Transmission Symetry General Amphicar Discussion 0
B transmission leak General Amphicar Discussion 2
L Transmission gear oil leakage General Amphicar Discussion 19
K Modified transmission mount bolts General Amphicar Discussion 0
G Transmission Rebuild General Amphicar Discussion 1
L Transmission oil seals General Amphicar Discussion 2
D Lake of the Ozarks transmission for sale General Amphicar Discussion 0
S Transmission Linkage pops out.... General Amphicar Discussion 5
W Transmission rebuilt cost General Amphicar Discussion 1
W Transmission rebild General Amphicar Discussion 1
W Transmission bearings and gaskets General Amphicar Discussion 0
D reversing transmission General Amphicar Discussion 0
R new transmission for sale General Amphicar Discussion 0
S Rebuilt transmission installed General Amphicar Discussion 2
E Transmission Input Shaft Radial Play General Amphicar Discussion 1
A Transmission Plug General Amphicar Discussion 2
E Transmission Removal General Amphicar Discussion 5
S Transmission Levels General Amphicar Discussion 2
S Transmission Dip Stick General Amphicar Discussion 1
R Is transmission venting necessary General Amphicar Discussion 4
D Transmission Bummer - Update General Amphicar Discussion 0
