Daniel & Kathy Gibson
Ok, so I get Amphi up past second gear for the first time, and there appears to
be some
tranny problems here. Here are the symptoms:
1. What appears to be a rotational grinding noise
2. The engine and tranny start to shake above 20 or so mph
It is faitly quite shifting as far as gear whine is concerned, but the two upper
gears have
that grinding sound. I jacked up the back end, and put it in gear and revved it
up some,
and sure enough, there was that shaking and noise.
So, here is what I pose to the group: Any ideas what part of the tranny may be
causing
this? Possibly u-joints? Fix or replace tranny?
This is a real bummer. Hopefully the fix is not too expensive, as I have spent
major $$$
(for me anyway!) so far, and cash is running a little low! May even ruin my
plans to go
swimming this Spring (D'oh!)
Any tips, advice, suggestions are welcome!
Thanks
Dan
'64 crippled Amphi (Cramphi?)
be some
gears have
up some,
causing
major $$$
plans to go
Thanks
Dan
