Trans bearing Play time Rusty Jack
Dave Derer
So...has anyone come up with a less costly replacement for the
"special"bearing by the pinion? Seems kinda strange that the race on
that bearing just totally fell apart, and there are no signs of any
damage or wear to any other parts of the tranny.
jem 6207 works.
Since I have assorted amphibian helpers doing lots of the work for My Swim In I
get to play. I have been trying to get into contact with any one with an
amphibious anything. I thought the German swimins are so cool with all of the
other makes and models. So if any one knows of anyone with an amphibious Please
let them know about get together. I emailed guy in California with red Camaro
style and only got automated reply.
At www.midwestamphicar.com ---under blue 64 ----That darn jack point rust is
detailed.
Marty call me when pool is filled! I will be on My way. Later Dave the Wave
D Trans Bearing, Defense of Hugh General Amphicar Discussion 0
AL67 trans parts General Amphicar Discussion 23
Jon March Water trans drive gear retainer clips: General Amphicar Discussion 7
D Ryan trans quarters etc General Amphicar Discussion 0
D trans wood General Amphicar Discussion 0
D Trans seal General Amphicar Discussion 1
D Check your trans General Amphicar Discussion 0
R trans General Amphicar Discussion 5
G Seal between water and land trans General Amphicar Discussion 7
A Trans or diff noise help!!! General Amphicar Discussion 0
G trans.rear lites General Amphicar Discussion 0
G Strange water trans noise General Amphicar Discussion 2
D Trans opinion General Amphicar Discussion 0
M bearing buddy General Amphicar Discussion 2
Midwest Amphicar Bearing buddy common mistake General Amphicar Discussion 3
Ken Chambers Wheel bearing grease General Amphicar Discussion 15
A Carbon Clutch Release Bearing General Amphicar Discussion 0
R 1296 small bearing General Amphicar Discussion 0
A removing inner front bearing race General Amphicar Discussion 0
R Stuck bearing race General Amphicar Discussion 8
L Rear Wheel Bearing Play General Amphicar Discussion 0
W wheel bearing General Amphicar Discussion 3
A Prop Shaft Bearing 3-19-2 Grease General Amphicar Discussion 1
E Bearing Protectors General Amphicar Discussion 0
G Bearing Buddies General Amphicar Discussion 1
R Wheel Bearing Protectors Available General Amphicar Discussion 0
A Carbon Throw-Out Bearing General Amphicar Discussion 0
J Carbon Release ( Throw Out ) Bearing Information General Amphicar Discussion 4
T Front wheel bearing removal? General Amphicar Discussion 5
A Front wheel bearing #s General Amphicar Discussion 1
B Main Bearing Caps General Amphicar Discussion 5
R bearing buddy General Amphicar Discussion 0
R Bearing retraction General Amphicar Discussion 4
E Transmission Bearing 2-16-29 General Amphicar Discussion 0
S New replacemnt 2-16-29 bearing, only $26 General Amphicar Discussion 0
A Front wheel bearing seal General Amphicar Discussion 2
S Front wheel bearing grease tool General Amphicar Discussion 0
M Is it a bad bearing? General Amphicar Discussion 0
D Front wheel bearing adjustment General Amphicar Discussion 0
C Wheel Bearing Help PLEASE! General Amphicar Discussion 0
C Wheel Bearing Packing General Amphicar Discussion 0
J Rear Wheel Bearing Seal Orientation General Amphicar Discussion 1
A Rear Bearing & Snap Ring Foepah General Amphicar Discussion 0
Jon March Pinch bolt side-play? General Amphicar Discussion 3
