anthony clark
Brian
On the subject of drive shafts, the manual i have
makes no mention of the springs situated on the drive
shafts, to keep the the shafts correctly located when
entering the water. I believe it was a later mod, also
the transmission mountings had a mod, the bolt which
screws into mounting was extend so it passes to the
bottom and an addtional mounting and nut is added i
have a copy of this mod if you want it, it just stops
excessive vibration, which can result in the gear
lever being pulled out of gear.
Hope this of use.
Tony Clark (White 64 UK)
Everything you'll ever need on one web page
from News and Sport to Email and Music Charts
http://uk.my.yahoo.com
Hope this of use.
