--- In amphicar-lovers@egroups.com, "Paul Lalewicz" <paul@a...> wrote:
> Arnold,
> I had the exact same problem with my 64, even with new radials.
Yes,
> was downright terrifying at speeds above 40 mph. Turned out to be a
> alignment problem with the culprit being the toe-in.
Arnold,
I had the same problem also with my white 67, the problem was indeed
the toe-in. From front view of the car, you could see without even
measuring that the right front wheel was off about an inch and a
half. This caused considerable wear on the edge of the tire. Problem
now solved, and no more wandering all over the road.
Rick Young
