Re: Re: Tires For the Amphi
John,
That is simply the neatest and best 1296 setup I've seen, as you say the carb
looks great and very close to original, more details and photos please ! What
sort of inlet manifold, which exact Weber carb and how did you jet it, how did
you route the exhaust manifold ? I assume it's small crank so standard clutch ?
The 1500 is a good engine for torque but in my experience always sounds rough
when reved, makes the 1147 feel like a six !
I'm sure by careful building some of that can be eliminated and the 1500 is
common here in Triumph based road cars but very rarely seen in racers, even the
guys who supercharge the engine prefer the 1296.
Another issue with the 1500 is most were built in the 1970s and there were a few
quality issues (understatement) in the Triumph product at that time, hence why
it all stopped in 1978. Also be aware that there are some 1500 engines and
components about there were never properly finished, in particular there are
crankshafts and camshafts around that were not properly hardened, be very
careful when buying NOS parts for these later engines !
David C.
Sent: Monday, July 05, 2004 8:08 AM
Subject: [amphicar-lovers] Re: Tires For the Amphi
Hello David,
There are two basic variations (and more minor subsets) of the 1296
over here, the small crank and the large crank. Both engines have the
same stroke but the large crank version has the larger journal
bearings like the 1500. The small crank version is more rare and
more often used by the race car guys because of its lower crank mass
which makes the engine slightly more responsive. There is a lot of
disagreement about the relative values of these variations but I
talked to a very experienced racer who has used the large crank
version, in racing, for years and swears by it. He claims the
beefier journal bearings make the engine far more durable and since
it still has the same stroke, the engine is even better at higher
RPMs. Hugh doesn't agree but I found the guy's story so convincing
that I just had a large crank version of the engine built up and will
be trying it out in my other car soon. I had the crank balanced and
the intake ports polished along with the usual hardened valve seats
and new exhaust valves. I also put in new chrome rings. I'm
expecting it to be a nice runner.
I just came up with a way of fitting the Amphicar air cleaner to the
Weber downdraft carb. and I'm real happy with the results. It makes
the whole engine installation look "correct". You can see a photo of
it at:
http://members.cox.net/jfriese/amphiwebercombo21.jpg
The installation not only looks good but the adapter looks like it is
a flame arrestor. I think the whole flame arrestor thing over here
is rather silly since the air cleaner will do a pretty good job of
killing any backfire flames and nobody seems to check for them
anyway. I've never used one on my car with the larger engine and
wouldn't know where to find one if I wanted to.
wrote:
> Hello David,
> My Amphi with the 1296 is much faster and more powerful than my
other
> Amphi that has an 1147. The 1296 engine also has a short stroke so
> it should have identical rev. qualities with the 1147. I suspect the
> increased piston diameter would result in a slight and
> inconsequential weight difference. In any case the car easily
> reaches 80 MPH and that's as fast as I want to go. It also allows
> me to climb 6% grades without downshifting from 4th. I've also run a
> 1500 in this car and really liked the additional power around town
> but I was worried about its long stroke and what freeway runs at 70-
> 75 MPH might do to it. So now that engine sits in dry storage. Too
> bad since the 1500 engine makes the Amphicar almost "fast" around
> town. Since I do rather lengthy, high speed, freeway drives in my
> cars, I didn't want to worry about the 1500 blowing up and found
the
> 1296 to be a good compromise for me.
> I've checked the speed of these cars with a GPS that reads down to
> tenths of miles per hour and find not only are my speedometers quite
> accurate but I can't say the tire difference is very consequential
to
> the readings.
> I have a tach in my cars and 75 MPH is about 5300 RPM. I don't
> remember what the revs. were around 80 but I would think it would
> still be under 6000 RPM.
> John Friese
> John, The short stroke 1296 is the exception ! That engine has the
GE prefix in the Triumph Herald (not sure of the Spitfire equivalent)
and revs as well as the 1147 - I didn't mention it because I didn't
think it was ever available in the States, I thought all the 1296 and
1500s were large crank ?, These are the engines that don't rev -
mainly because there are some fundemental problems with crankshaft
balance that were never properly solved. The small crank 1296 is a
rare engine here because so many have been used for racing over the
last 35 years but I have one I plan to fit before long. I thought the
revs were a bit higher than 5300 at 75 but haven't checked my rev
counter ! The other thing that makes a difference at high revs is
engine breathing - things like the exhaust routing and that silly
flame arrestor that is fitted to US cars.
> David C
> [Non-text portions of this message have been removed]
THE AMPHICAR-LOVERS LIST
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
